I understand how the Loadomatic works along with its related Spark Control Valve.
Here's my problem. I believe specifications for a '65 200 state that there is no vacuum from the carb to the distributor at idle which would yield no vacuum advance.
Yet, even if I set the idle at 350 RPM, I'm getting some vacuum which gives me perhaps 2 degrees of added advance at idle.
I presume this may be from having an improper carb on the engine. The carb may be from a 170 with a slightly smaller venturi which generates greater vacuum. Or it may be normal for the carbs that were supplied with trucks which appear to have a vacuum port below the throttle plate this is exposed to the venturi vacuum at idle. .
Can't really see any problem this would cause. Can you?
The second issue is with the distributor. The breaker plate advances with vacuum but doesn't return fully. There's perhaps a couple of degrees added advance when I return to idle. Is this normal?
Before I go assuming that the distributor is gummed up I wonder if the advance is holding air that's supposed to bleed off?
Any of your thoughts would be appreciated.
Eddie in NY
'65 200 in a '67 Econoline pickup
