by MPGmustang » Sat Jul 31, 2010 11:18 pm
IIRC on my old stock engine... I pinged under load if I went above 12 TDC, drive ur hills at WOT and make sure you don't ping, if you do back it off 2* until it don't.
My old engine with the autolite 1100 and LOM distrbutor liked idle at no less than 650 rpm with my T5, I have A/C so I bummped it up to 850rpm so the A/C could kick on and be perfect idling. Another suggestion, maybe the alternator is going out, less spark = rough Idle?. I would also try makeing your plug gaps smaller, store is usually .045 i'd try .040 or even .035 and see what's best. it's all trial and error. check your gas/air screw on your carb see if the tip is still intack (with the engine off). stock engines love 20 hg vacum, Confirm that you CAN reach that, what's the rpm? I recomend to stay there. it's happy and it's getting it's way (kinda like women).
Richard
-_________ ******* DD-
Sande-65 mustang,
/_________\ ****** 264/274 110* with 1.75 int/1.5exh large hex log ported
[[[___o___]]] ***** DUI, 1100 Pony Vaporizer
|__|--0--|__| **** 67 bh with 4cyl T5, ClassicInline Headers
*\ \ \******\ \ \***** 17mpg city, 205/70r14
*/// ******/// **** future fun- 65 front bench
