Demon 98 / Petronix
A forum for the Ford Flathead Six and the 215/223/262 OHV Six.
Demon 98 / Petronix
Postby texas_rat_trap » Fri Nov 06, 2009 3:08 am
Anyone runnin' a Barry Grant Demon 98 on there ride...well they don't have a metered vacuum port for vacuum advance distributor. Thinkin' about going with the Petronix setup and was wondering if anyone eles has used it and if you can feel a big difference in performance with the electronic ignition?
" Ain't No Crime Runnin' Inline"
1953 Ford Mainline 2dr Post **I need a Grille for a Mainline,Customline or Delivery**
1948 F-100 Custom
texas_rat_trap
Re: Demon 98 / Petronix
Postby fmartin_gila » Fri Nov 06, 2009 7:13 am
Can't offer any help with the carb, but I do run a Pertronix I with matching coil. Very easy install, slight improvement in mileage and ease of starting, and most of all trouble free. I did pick up a Mallory dual point centrifical distributor some time ago that I figured to use if I ever decided to change to a different type carb. I am still running the Holley 1904 carb and the LOM distributor and the setup with the Pertronix install has been running very good for better than 5 years now. This is on a 62 F100 with a 223 with a T5 behind it and still running the 3.70 rear.
Fred
62 uni
fmartin_gila
Postby texas_rat_trap » Sat Nov 07, 2009 3:05 am
How in depth is it to install a T5 behind the 223
1948 F-100 Custom
texas_rat_trap
Postby fmartin_gila » Sat Nov 07, 2009 7:53 am
I used the adapter kit made and sold by John Mummert at www,ford-y-block.com. He will furnish all you need to install a T5 to the bell, including a new proper clutch setup. Almost a bolt in, you will need a shorter driveshaft.
Fred
62 uni
fmartin_gila
T5 adapter
Postby texas_rat_trap » Thu Nov 12, 2009 11:44 pm
How much $ are we talkin'.....ball park on the John Mummert T5 adapter kit?
Last edited by texas_rat_trap on Fri Nov 20, 2009 12:51 am, edited 1 time in total.
1948 F-100 Custom
texas_rat_trap
Postby 59Orphan » Sat Nov 14, 2009 7:55 pm
Just find a 1957-60 223 ford f-100 bell housing and weld a slug on to the bell housing then thread the slug. 3 of the 4 bolts line-up. Then get a 1994 or later t5 mustang transmisson. You will have to change out the speedo from electric to manual. Be sure to measure where the shifter location is going land. Change out the throw out bearing and shorten the driveline. Can't think of much else. I well look around for a couple of helpful website. ie. 223 ford t5 swap. If you have the transmission I think all could be done for $250.
1959 F100 223ci/Turbo/Holley 500cfm/9" 3.70/ 3 on the floor
59Orphan
Postby fmartin_gila » Sun Nov 15, 2009 7:44 am
Been over 5 years since I changed mine over to T5 so may be a little more now, don't know. He charged me 400 plus shipping, this included the fully machined adapter plate with the proper attaching bolts, a new clutch disk, a new diaphram pressure plate, a Throwout bearing mounted on a machined collar to fit on the T5 input tube & to work with the throwout fork on our early vehicles, a proper sized pilot bearing to mate the input shaft to the hole in the crankshaft, and a good set of directions. He has it all worked out so it is almost a bolt-in. I did have to shorten the input shaft about 5/16 of an inch to allow the crankshaft to have some endplay (he covers this in his directions), very easy to do with an air powered cutoff wheel, could use a dremel. I also had to massage the flat portion of the floorboards some to create a slight roundness because the T5 is somewhat (about 1 inch) taller from the mainshaft centerline to the top of the shifter housing than the 3.03 because the 3.03 had the side shifter levers. Also had to use a shorter driveshaft. The output yoke is the same size and spline as the 3.03 so I used my old one, but I did cut it off about 1 & 1/4 inch in order to minimize wear on the output bushing. As I said, he has it all figured out so it is basically a bolt-in and you don't have to re-engineer anything. I did the entire changeover in one afternoon. Another reason for my choice to use his "kit" was that the closest Junkyard to my location is over in Thatcher, about 55 miles from me, so I didn't have to try to find something that might work together. As to the shifter position, I just made a small plate out of 1/8 inch steel to move the upper shift lever about 3 inches to the front as the lower lever comes up just in front of the seat bottom, the offset from the lower to the upper shift lever allows the trans to be shifted to the 2, 4, & R positions without interferance with the seat. I am very well pleased with how it has worked out. It has not caused an problems and is very reliable. I have driven all over the country since and would not hesitate to drive it anywhere at anytime. If you need any more info, let me know.
Fred
62 uni
fmartin_gila
Postby JimKoz » Sun Nov 15, 2009 1:36 pm
Here's a link to the DIY swap. It uses the 3-speed bellhousing and a Chevy S-10 T5
http://badgerlandf100s.com/techcorner/
JimKoz
Postby flatford6 » Sun Nov 15, 2009 2:01 pm
One thing to remember is that the pickup bell bousing is thicker front to back than the car one so a spacer would probably be required for this same swap into a car. The pilot bearing adapter would be the same. The sleeve inside the throwout bearing would be a different diameter or wall thickness but the principle is the same. Notice the nice position of the shifter handle using the s10 trans. Most of the Mustang T5s have the shifter handle back near the rear end of the tail shaft housing. Nice swap.
flatford6
T5 adapter
Postby texas_rat_trap » Fri Nov 20, 2009 12:50 am
On the John Mummert Mustang T5 adapter...Will I have shifter to seat interference issues? $179.00 for the adapter not bad price. The adapter he is selling, is that just a modified bellhousing?
1948 F-100 Custom
texas_rat_trap
Postby fmartin_gila » Fri Nov 20, 2009 7:59 am
The adapter he sent me was a very beautifuly machined piece that fit exactly as it should on both sides. It mated up to my bellhousing and the Trans bolted up to it as it was designed to do. You also need the TO Bearing carrier that he has worked out to make this an easy installation. As I stated already, he has worked out all the problems for you, why try to make it harder on yourself? It is a lot easier to make up a little plate to move the upper part of the shifter forward than it is to deal with all the problems associated with mating the S-10 shifter parts to the Ford T5. Why are you trying to make it harder to do, just pay the few extra dollars and take advantage of his engineering. I have found over the years that it is a wise decision to utilize good engineering over trying to setup something that may or may not work and winding up with a scrapped project or something that is a dissatifaction to use. Sorry to come across like this, but I have found no one that is dissatisfied with John Mummert's products or his engineering. He puts out some very well thought out products and you will be shortchanging yourself if you try to shortcut doing some project that has already been worked out. I have Been There - Done That in the past.
Fred
62 uni
fmartin_gila
Return to Vintage Ford Sixes
