My 300 build (PICS)
My 300 build (PICS)
Postby Tha_Stepside » Mon Nov 17, 2008 11:49 pm
Ok, I have gained a significant amount of knowledge from this site about the legendary ol 300 and now I have completed my build.
-300 bored 0.030 over with Speed Pro Hyper pistons
-Shot peened rods, ground crank
-Zero-decked block and head has been shaved 0.010" with three-angle grind, spring seat step was shaved for new valve springs.
-Very mild porting and polishing
-Crane 260H cam with lifters and dual spring valve springs
-Offy C intake and EFI exhaust manifolds with 600CFM Performer (I know its a big carb, but it was free, and its only temporary)
-MSD Blaster 2 coil and wires, mallory cap and rotors (all not in pics unfortunately)
-Rhinopac heavy duty clutch
-All painted with Caterpillar coulors seeing as I am a CAT mechanic I thought it would be a cool color for the engine.
Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image
Tha_Stepside
Postby Asa » Tue Nov 18, 2008 12:10 am
nice engine you got there, what you gonna be using her for?
needed to resize those pictures for you, too many and too big to post 'em all as one
check this thread to see how i did it
http://fordsix.com/forum/viewtopic.php?t=54283
Right and Wrong are just words, what matters is what you do
Susie - a work in progress
Clyde - ya mule!
Asa
FSP Moderator
Location: South Sassafrasse, with them sweet Tallahassee lassies
Postby TCIC 300ci superbeast » Tue Nov 18, 2008 12:46 am
looks like a 72-79 f100-150 (no leafs in the front).
4x4
looks sort of like a cat. motor with the yellow and black.
1978.5 f250xlt ranger custom super-cab 4x4 "superbeast" turbo300/ZF S542/BW1350/np205d dana 44HD/dana60
dec.1978 f150xlt custom 4x4 "six shooter" parts truck for super beast
2004 2.0 dohc 5speed focus DD "toycar"
truck club OHIO MUD SLINGERS
walk softly and carry a big six
Location: yellow springs ohio just south of springfield and just east of fairborn
Postby Asa » Tue Nov 18, 2008 12:47 am
ok, that's what truck it's in, but what does that have to do with what he's going to be using it for?
Clyde - ya mule!
Asa
FSP Moderator
Postby Harte3 » Tue Nov 18, 2008 1:13 am
Most excellent :!: You would gain another 20 hp and 15# of torque with a Cummins "Red Head" paint job though. :lol: :P
Harte3
Postby Tha_Stepside » Tue Nov 18, 2008 1:20 am
Thanks for the kind replies, its going in a 78' F150 4X4 flareside with 35" tires and 4.11 gears. I would have done a cummins paint job, but the only cummins engins I work on are grey and V24's. Almost all the CAT engines I work on have the yellow and black scheme for paint.
Tha_Stepside
Postby mutt » Tue Nov 18, 2008 1:35 am
i like a snappy paintjob. what did you use for paint?
mutt
Postby inline300 » Tue Nov 18, 2008 9:15 am
Ill give you a 10 for paint originality. :D
Wanted: clifford 264H (240,300) or comp cams 268H, good used condition ok.
inline300
Postby THE FRENCHTOWN FLYER » Tue Nov 18, 2008 11:27 am
Nice job!
Postby Geezer 300 » Tue Nov 18, 2008 11:28 am
Quite interesting, let us know how it works.
77 Ford 300 500 Performer, Offy C, BBF 1.73 rockers, dual oil filters w/oil cooler, Jacobs ignition, 5 spd o/d tranny, 3.55 Dana 44, Pacesetter headers...more to come
2004 Mustang SVT Cobra convertible
Geezer 300
Postby willowbilly3 » Tue Nov 18, 2008 11:42 am
inline300 wrote:Ill give you a 10 for paint originality. :D
Yeah, I don't normally deviate from Ford blue but that is classy.
Great ideas have always encountered violent opposition from mediocre minds
Albert Einstien
willowbilly3
Postby Broncitis » Thu Nov 20, 2008 10:12 pm
What a very nice job, I only disagree with the cam, the grind has been around for forever, same grind I used in the mid 80's and disliked then and now, put yourself a 212 to 214 duration at 110 lobe speration at about .450 to .500 lift and you will be amazed, 204 at 112 on the intake with the jugs and stroke you have is a waste of potential. always just an opinion, but one based on experience.
69 Early bronco, 4.11, toploader 4speed, 68k 3inch body lift, ET about 50 something!!!
Broncitis
Postby AbandonedBronco » Fri Nov 21, 2008 4:57 pm
I love the yellow/black combo. The only paintjob on a 300 I've liked almost as much was a camouflage paint scheme (that one was awesome.)
Very cool.
1981 Ford Bronco 300. 3.00 final drive, 4 speed OD manual. 4bbl Holley 390 w/Offenhauser DP Intake. EFI manifolds and 2.5" exhaust.
Sixes owned:
1957 Chevrolet 150 Sedan 235ci I6.
1987 Toyota Supra Turbo 183ci I6 (3.0L)
1981 Ford Bronco 300ci I6.
Never owned a V!
AbandonedBronco
Postby FlareSide » Sun Nov 23, 2008 5:31 pm
Nice paint!
I'm a fan of CAT I6 motors so I think a 300 painted in CAT colors is a cool idea.
Ole' Betsy
'94 F150 FlareSide
31x10.50 Dayton MT Mudders
4.9L / 4.11 / Powertrax No Slip Locker
My truck thinks she's a tractor.
Happiness is not something you find, but something you create.
FlareSide
Postby StrangeRanger » Sun Nov 23, 2008 7:24 pm
Broncitis wrote:What a very nice job, I only disagree with the cam, the grind has been around for forever, same grind I used in the mid 80's and disliked then and now, put yourself a 212 to 214 duration at 110 lobe speration at about .450 to .500 lift and you will be amazed, 204 at 112 on the intake with the jugs and stroke you have is a waste of potential. always just an opinion, but one based on experience.
The higher duration, narrower LCA cam will produce higher peak torque more power at higher RPMs but it will also result in a narrower torque curve. For a lot of us, the virtually flat torque curve from 1800-3000 is the principal virtue of the 300. Nearly every cam manufacturer except CompCams grinds their towing/hauling and mid range street cams on a 112° LCA.
1996 F-150 (tow missile)
1993 Mustang 5.0 (hot rod and auto-x monster)
1982 Tiga Formula Ford (SCCA racecar)
2006 Mazda 6i (daily driver)
StrangeRanger
Postby 9.ford.5 » Mon Dec 08, 2008 12:41 am
Tha_Stepside wrote:Thanks for the kind replies, its going in a 78' F150 4X4 flareside with 35" tires and 4.11 gears. I would have done a cummins paint job, but the only cummins engins I work on are grey and V24's. Almost all the CAT engines I work on have the yellow and black scheme for paint.
ha the good ole n14 eh
i love the CAT look nice build man get er to the dyno ASAP
9.ford.5
Postby ford man 69 » Mon Dec 08, 2008 8:38 pm
pretty sweet that cat yellow is a diffrent color that stands out in a good way i would have painted the harmanonic balncer black though 8) (i know i cant spell)
ford man 69
Postby TCIC 300ci superbeast » Mon Dec 08, 2008 8:52 pm
but that makes it look even more like a cat.
Postby American Thunder » Mon Dec 08, 2008 11:32 pm
Looks badass.
I always go with dark Corporate blue on Ford motors, but I like the cat colors on there, too. (My flatbed wrecker has Cat power, so I'm used to seeing those colors)
1977 530hp 302 Mustang II videos:
Smokeshow at 8000 rpm
0-90 mph speedometer view
1983 4x4 Bronco - '95 300 converted to carb, 5-speed, 3.55 gears and 9" rear.
American Thunder
Postby Tha_Stepside » Thu Dec 11, 2008 10:09 pm
Thanks for the kind words guys, I have ran out of time to do any more work on it, but as soon as I get it running and moving around you guys will be the first to see it.
Tha_Stepside
Postby JackFish » Thu Dec 11, 2008 10:49 pm
I just stumbled on this thread, and I think yellow is a GREAT choice.
:wink:
It would appear GREAT minds think alike.
Although in my case, I just couldn't bring myself to conform:
Yup, I bought another one.
1996 Chevy Caprice 9C1
JackFish
Postby Tha_Stepside » Sat Dec 13, 2008 1:30 am
THATS what I like to see, more yellow engines. Great minds do think alike eh?
Tha_Stepside
Postby econovan » Sun Dec 14, 2008 1:36 am
My friends call it the yellow submarine engine :)
It's a '75 300 and it'll go in my '66 econoline van.
-speed pro hypereutectic pistons 30 over
-melling torque cam
-milled head .030, valve job; ground, champered and polished crank
-new cam bearings & freeze plugs
-new sleeved guides
Got it back from the machine shop last week and am in the process of assembly.
The color is Daytona yellow from advanced auto parts. Bolts and pulleys are painted black.
I'm going to use the intake/exhaust manifold of a 240 until I can find
something better.
Cheers :D
[/img]
econovan
Postby Geezer 300 » Sun Dec 14, 2008 12:06 pm
Color will definitely wake you up !!
Geezer 300
Postby Tha_Stepside » Sun Dec 14, 2008 2:24 pm
econovan... I totally dig the colour of the head bolts, nice attention to detail.
Tha_Stepside
Postby FlareSide » Sun Dec 14, 2008 6:32 pm
Gorgeous!!!
Ole' Betsy
'94 F150 FlareSide
FlareSide
Users browsing this forum: Google [Bot] and 4 guests
cron
