Hampton wrote:.....90 miles of that is interstate at 80mph. Currently its getting 17mpg....
Even if the rpm is theoretically optimum, where are the throttle plates at cruise?
StrangeRanger wrote:.....
Personally, I'd leave the 3.08s in it and concentrate on cleaning up the aero. There's probably more MPG there than in the gear swap.
StrangeRanger wrote:Even if the rpm is theoretically optimum, where are the throttle plates at cruise?
That wasn't theoretical, it was empirical (i.e. observed) data over several thousands of miles with the 3.08 gears in my F150. Because of the difference in OD ratios, 3.08 gears with an E4OD gives the same overall top gear ratio as 2.73s with an M5OD. The 3.08/E4OD combo was good for 19+ highway, including a Knoxville-Akron run over the WV turnpike and many north to south runs through OH. It pulled hills well and hardly ever dropped out of OD. It was a stone around town, but his question was highway mileage. The 2.73/M5OD should at least the equal the mileage I experienced.
As to the gear ratio, If you compare the overall reduction of a T-18 starting in 2nd gear with a 3.55 final drive (which is 3.09 x 3.55 = 10.96) to an M5OD starting in 1st with a 2.73 (3.90 x 2.73 = 10.65) you'd see there's not much difference. You lose the creeper gear for getting a trailer moving, but again that was not his question.
Harte3 wrote:An example of observed empirical results would be the significant difference in power when running winter blend diesel or straight #2 diesel pulling heavy loads in a big truck. On the blended fuel, I would have to drop one gear on most grades that I would pull in the next higher gear on #2 fuel. That was 101,000# GVW loads in the Pacific Northwest...hated using that blended fuel.
StrangeRanger wrote:In order for them to legally replace a converter, it must be either clogged or damaged.
Users browsing this forum: Google [Bot] and 4 guests
