69 F 100 Aman wrote:I wanting to put a electric fan on my truck, rad core is 26"x19" and I have about 4" to play with form the engine.
I've just purchased the Taurus 3.8L fan / shroud assembly (by Dorman) new via RockAuto for a delivered cost of about $114, and I'm sure it will satisfy your cooling needs. However:
Even without the shroud, it is almost five inches front to back. If your clearance issues are the same as mine, you cannot install this thing directly in front of the water pump / in line with the existing fan / shroud.
If you pull all the existing fan and shroud parts and then offset the new stuff by several inches towards the driver's side of the vehicle, you should be able to clear things fine.
I wanted to retain the effectiveness of the factory designed shroud, so I am looking at mounting the new fan / shroud system within the old, with the OEM shroud generating a strong pull across the entire core, even if it's the electric fan doing the pulling.
If you want another shroud to play with, they CAN be very cheap. For my year truck, it was just $21 delivered for a brand new shroud. I can cut up on it all day long, totally screw things up, and still have the original unmodified shroud to ball back on.
Provides a nice comfort factor from my perspective.
