trying to ID this bell (the pattern) it looks like to put a ford T5 behind it on a spacer I will need to drill the "dual" pattern for the upper holes but have no idea on where to locate them proper (IE so they will work with what SHOULD bolt there) can you guys help me out here? I have a T5 bell also I will be running but figured I would maybe ge a second setup for the spare motor.
