CI head install back on track.
Small Six aluminum cylinder head information.
Postby RPMustang » Tue Nov 03, 2009 1:54 pm
Ok, 3 months later and I finally have repaired (http://www.Robaldo.com/ProjectLazzarus) enough of the accident damage (http://www.Robaldo.com/CarWreck) on my son's 66 coupe to get the CI head install back on track.
So now I'm posting some photo's of the install. And hopefully some of you can give me a hand with some ideas for any problems I run into.
The block as it was right after pulling the cast iron head off, All that water in Cyl 6 came out of the block when we pulled the head.
Here we've cleaned up the block & installed studs:
Next we put the head gasket in place, being sure that it's not upside down:
Now it's time to bolt on the head:
Then the intake, it took a substantial bit of precussion engineering to get the necessary clearance:
Finally, we come to the carb. I'm open to suggestions on this one. Which way should I face the carb, & ANY ideas to hook up the throttle linkage would be welcome.
Thanks,
Lance Robaldo.
RPMustang
Re: CI head install back on track.
Postby Ronbo » Wed Nov 04, 2009 7:18 am
By chance, did you put any sealant on that front/left stud? It goes straight into a water jacket. When I pulled my old head I had leakage there. I also had slight leakage around those pin-hole water passages. I'm hoping the studs will help with that. Got dizzy looking at the pictures, they was spinning round and round :lol:
Ron
83 Bronco, 300, SROD, 32.5 X 11 BFGs, headers, Offy DP w/ Holley 390, MSD box, soft top
68 Mustang, power drums/steering, AC, single outlet coated header, DGES, DS II w/Accel super coil
2008 Pathfinder
Ronbo
Postby Gene Fiore » Wed Nov 04, 2009 10:14 am
Also make sure to check that the water pump impeller doesn't kiss that front/left head stud. You may have to grind a bit off the bottom of that stud to clear it...I did. :wink:
1971 Maverick Grabber, 250cid, 350 Holley direct mount on log head, 1.6 rockers, mild port and polish, Hooker dual headers, FSP DUI dizzy, C-4, 8" 3.55 detroit locker
Best ET 1/4 mile: 16.32 at 81.39 mph on 11/16/08
My Classic Inlines Photo Page
Gene Fiore
RC Moderator
YEAH FINALLY!!
Postby FalconSedanDelivery » Wed Nov 04, 2009 8:24 pm
Finally someone is installing the carb in the Correct direction , good luck with the build
Falcon 6's, FE's I Like them all ( own both ) My FE 671 Blown 390 in my Real Street Car 1968 Mustang 10.55 133.87 in Pa street legal trim and 92 Pump[ gas at 3675 lbs , 65 Mustang 250 Six ???? , Will know in May !!2009 mid 13 at least
FalconSedanDelivery
Postby 66200i6 » Wed Nov 04, 2009 11:31 pm
Do a search for "4V clearance issues". I had posted a view of my install of a Holley 390 installed in the same orientation that you show in your mock-up.
The description is in the post. There are many other examples as well from other intallations that were going on at the same time.
Have fun, Ric.
Ric Tucker
63' 2 Door 200 I6 (NEW)
66' Coupe 200 I6
66' F250 Camper Special
71' F100 Sport Custom
66200i6
Postby RPMustang » Wed Nov 04, 2009 11:35 pm
Sorry that was just a picture taken i am actually mounting the carb with the fuel bowl facing towards the firewall
RPMustang
Return to Aluminum Cylinder Head
