throttle linkage
Small Six aluminum cylinder head information.
throttle linkage
Postby RPMustang » Tue Nov 03, 2009 12:21 am
i have some ideas on how to hook up the throttle linkage, but i am curious if anyone can share what they did that may be more efficient than what im thinking. I am running an autolite 2100 with an automatic transmission.
66 Mustang Cp
C.I. aluminum head
Autolite 2100 carb
DUI distributer
Alum. radiator
Painless wiring harness
Custom upholstery
6 gauge cluster
65 Mustang Convertible
T5 5 speed Transmission
Weber 38/38 Outlaw carb
Alum. radiator
Pertronics electronic ignition
Dakota Digital inst. cluster
Flo-fit "Pony" seats
Lance.
RPMustang
Re: throttle linkage
Postby shmoozo » Thu Nov 05, 2009 7:14 am
RPMustang wrote:i have some ideas on how to hook up the throttle linkage, but i am curious if anyone can share what they did that may be more efficient than what im thinking. I am running an autolite 2100 with an automatic transmission.
Most folks seem to just switch to using a throttle cable setup from a later model car including the pedal assembly rather than trying to adapt the factory linkage.
"Every normal man must be tempted at times to spit upon his hands, hoist the black flag, and begin slitting throats."
-Henry Louis Mencken
shmoozo
Postby Mustang_Geezer » Thu Nov 05, 2009 7:47 am
My carb is oriented with the primaries facing forward and I swapped to a throttle cable that pulls towards the fire wall.
I'm running a 67 valve body (in a C4) with a transgo shift kit and I manually shift it so I never made any provision for a tranny kickdown cable.
Works for me. :)
Later,
Doug
Mustang_Geezer
RC Moderator
Return to Aluminum Cylinder Head
