96 mass air harness
EFI tech and support
96 mass air harness
Postby mostly_broncos » Mon Nov 02, 2009 8:52 pm
I have a truck that im parting out and it has mass air injection. I had planned to sell the brain and the whole harness along with the MAF sensor and air box hoses and everything that would be needed to convert an older truck to mass air.
Being mostly a 351w guy I was surprised to see that it has a crank sensor and a special pulley/damper that goes with it as well as a special front cover where the sensor mounts. If I'm going to sell it as a kit then I think the front cover and damper need to go with it
I'd heard that 96's were OBD-II which makes it less desirable I think as a swap donor but I can't find an OBD-II connector. If it is OBD-II shouldnt they have a connector under the steering wheel? or were they located somewhere else in 96.
The part number on the computer is an F6TF-12A650-ED and it has a lot more pins than what you'd expect from an EEC-IV processor .
mostly_broncos
Re: 96 mass air harness
Postby StrangeRanger » Mon Nov 02, 2009 8:56 pm
The OBD-II connector is under the right hand edge of the ash tray.
That's not a crank sensor on the damper, it's a misfire sensor.
1996 F-150 (tow missile)
1993 Mustang 5.0 (hot rod and auto-x monster)
1982 Tiga Formula Ford (SCCA racecar)
2006 Mazda 6i (daily driver)
StrangeRanger
Postby mostly_broncos » Tue Nov 03, 2009 6:48 pm
Ok I see the connector Thanks. :D
I thought it would be a nice setup for someone to put in an older truck but the OBD seems like more than most people would want to screw with.
mostly_broncos
Postby StrangeRanger » Tue Nov 03, 2009 7:34 pm
The problem with OBD-II is that it's designed to detect "tampering" and set off error codes when it does. The 96 has an early version of OBD-II which won't rat you out like some of the later versions but it is not as modification friendly as the OBD-I mass air systems used in Foxstangs.
StrangeRanger
Postby mostly_broncos » Wed Nov 04, 2009 10:05 pm
If it detects "Tampering" does it just throw a code and go about its business or does go into some sort of reduced functionality mode?
If the crank sensor is only for misfires then its not involved in triggering spark in any way?
mostly_broncos
Postby StrangeRanger » Wed Nov 04, 2009 10:21 pm
Some failures put it in limp mode but i cannot tell you which ones
The misfire sensor has nothing to do with spark timing; that is handled by the PIP in the dizzy.
StrangeRanger
Return to Fuel Injection - Mega Squirt
Users browsing this forum: '68falconohio and 1 guest
