However...today's gasoline reduces the hydrocarbons for you, even more than the slow spark curve did. So, get a set of the Mr. Gasket #925D distributor springs and modify your distributor as follows:
1. Remove the lighter of the 2 springs in the DII and replace it with one of the #925D springs. DO NOT replace both springs with the #925D springs (more on that in a moment).
2. There is a support arm that holds the larger spring, on it's non-slotted end. Bend this arm in toward the center of the distributor, just 3/32".
This combination replicates the "police interceptor" distributor spark curve for the 200 I-6, according to a local "guru" who helped build these for Ford in the early 1980s. It causes earlier spark advance up to 1200 RPM, which then remains steady until 1800 RPM, when the secondary spring starts its advance. This "plateau" of early advance, limited by the 3/32" inward adjustment of the heavier spring, provides more torque at around-town speeds. Ths improves your MPG because you don't have to open the throttle as far to get the same speeds you were running before. You'll also notice better off-the-line pep and cold-running performance. Mine also starts a little better when hot, and the plugs stay cleaner. My in-town MPG rose from 16.5 average to 18.1 average over 2 tanks of gas, winter driving to and from work. I haven't tested the highway MPG yet, but I don't think it will improve from the 23+ I've been getting. I'll re-post if it does.
If you make the mistake of replacing BOTH springs in your DII with the #925D springs, you will get a SLOWER spark curve unless you extensively modify one of them to provide a "slot", like the heavier spring already has: but I found, even after that exercise, that the engine "hit the wall" at about 2200 RPM and would not accelerate well up hills. Adding in the heavier spring, but delaying its effect until 2000 RPM, did the trick: now it loves to rev, even on regular gas (my compression is about 9.4:1). The maximum advance is reached at 2600 RPM on my engine with this mod: before, the max advance was at 3200 RPM.
