Here's the 300 forged crank "casting" number.
Postby Bret » Sat Oct 27, 2007 7:46 pm
Some years ago I remember people on this forum requesting the part number found on the 300 factory forged crankshaft. I ran across this number in the Popular Hot Rodding 1977 "Engine Annual". The Annual has an article about Bruce Sizemore's Pro Stock Pinto.
The Pinto had the 300 with a cylinder head hand-built from 351C sections. It produced over 500 HP. Sizemore used OEM forged cranks, but had them cross-drilled, and offset-ground (to reduce stroke).
Without further ado, the 300 crankshafts to watch for have the number; C6TE-G on them. We should all memorize this number: C6TE-G. This crank can be found in heavy duty/industrial applications and even sometimes in the F100 and F150.
C6TE-G
Don't let them go to the crusher.
Bret
Postby Fordman75 » Sat Oct 27, 2007 8:15 pm
You forgot the C5TE-F.
Ted
54 Ford F100/F250 4x4
Fordman75
Postby Bret » Sat Oct 27, 2007 8:58 pm
Fordman75 wrote:You forgot the C5TE-F.
Darn it! I hauled all my C5TE-F cranks to the crusher last week!
Just kidding. We now have two numbers to remember.
C5TE-F
C6TE-G
Legend has it...that the forge crank motors also use a cast-iron water thermostat housing, or goose neck. Anyone know about this?
Bret
Postby Fordman75 » Sat Oct 27, 2007 9:05 pm
Most of the 300's I've owned have had cast iron T-stat housings and cast cranks. :P
Ted
Fordman75
Postby Ferris Bueller » Sat Oct 27, 2007 11:09 pm
So is this number stamped into the crank. If so, where on the crank? I'm guessing the 71 F600 I once owned had a forged 300 crank. What about my 94 heavy duty F250? A local marina has a boat lift with a 300 in it. I should chat with them about the 300 and leave my number in case they swap out motors sometime down the road.
Parts 92 F150 XLT 4x4 ext 300 5sp 136k
93 F150 140hp 300 5sp 2wd 2.73 201k uses no oil
94 F250HD 140hp 300 ZF-5sp 4.10 93K
04 Ranger 2.3 5sp 143hp 3.73 123k econo truck rocket (compared to the others)
Ferris Bueller
A couple of photo shots
Postby super4ord » Sat Oct 27, 2007 11:52 pm
Image[/img]
super4ord
Postby Lazy JW » Sun Oct 28, 2007 10:06 am
Looks like C6TE6 to me :?
74 F-350 300-6, EFI manifolds into single exhaust, Carter YF, T-18B, Dana70 w/4.11, Flatbed dually w/dump bed. Great farm truck!
Lazy JW
FSP Moderator
Postby THE FRENCHTOWN FLYER » Sun Oct 28, 2007 10:13 pm
No - its a "G". The suffix part of the part number generally is a letter, denoting the revision level of the part. An exception to this is if there two suppliers of the part then the suffix will have an alpha-numeric component, different for each supplier.
Postby 66 E100 Pickup » Sun Oct 28, 2007 10:51 pm
I can't remember in my browsing here...were there 240 forged cranks?
John
66 E100 Pickup
Postby Fordman75 » Mon Oct 29, 2007 12:45 am
No.
Ted
Fordman75
Postby ranger » Tue Oct 30, 2007 5:40 pm
C6TE 6303 G
C6TE = application
6303 = basic part #, crankshaft
G = revision
ranger
Postby pssnmn1 » Tue Oct 30, 2007 9:41 pm
hey super cool modeators please post those in the sticky
pssnmn1
Postby tjm73 » Tue Oct 30, 2007 10:20 pm
Has anyone on the board ever broken a "regular" factory cast crank?
tjm73
Postby addo » Wed Oct 31, 2007 4:02 am
Chuck Norris did, but we had to ban him...
addo
Postby pssnmn1 » Wed Oct 31, 2007 8:03 am
i think it was a round house kick
pssnmn1
Postby motocentro » Wed Oct 31, 2007 10:11 am
CN jokes just don't get old. . . :lol:
motocentro
crank
Postby Gord » Wed Oct 31, 2007 6:59 pm
the guys that ran my race car back in the 70's actually broke a steel crank about every 25 runs, of course they were revving the engine to 8500 rpm, they said every crank broke in exactly the same place. Back then I am not sure the balancing is as precice as it is today and certianly the crank dampers were no where near as good as a modern ATI damper. Those two things alone could make the difference in the life of a crank in a race motor
Gord
Re: crank
Postby tjm73 » Wed Oct 31, 2007 11:05 pm
Gord wrote:the guys that ran my race car back in the 70's actually broke a steel crank about every 25 runs, of course they were revving the engine to 8500 rpm, they said every crank broke in exactly the same place. Back then I am not sure the balancing is as precice as it is today and certianly the crank dampers were no where near as good as a modern ATI damper. Those two things alone could make the difference in the life of a crank in a race motor
hmmmmm......makes me wonder why anyone really thinks they need a forged steel crank????? You're not turning crazy revs and you aren't making 600+ hp.
Other Ford cast cranks have been known tro begin failing around 600 hp. But they don't have the bearing-rod-bearing-rod-bearing-rod-bearing-rod-bearing-rod-bearing-rod-bearing configuration which is better support.
tjm73
Postby SuperMag » Fri Jan 11, 2008 10:53 pm
Added FAQ Material:
Q: how can i tell if i have a forged crankshaft?
A:
thunderbolt wrote:The easist way to tell a cast crank from a forged crank is to pull the pan on the engine in question and look at the parting lines on the throws.
Thin parting lines with some factory flash on them= CAST
Thick parting lines that are relatively smooth semi rounded in appearance= FORGED
Forged cranks do not have casting #'s .The numbers are "stamped" into them at the forge.
Some factory cast cranks, not just Ford ,are what is referred to as "cast steel" "high nodular iron" or "armasteel".
They are very reliable and strong pieces plus they are cheaper to produce than a forged crank.
A forged crank would only be necessary for the most extreme duty service.Heavy trucks doing low rpm lugging,or very high horsepower applications.
Q: which vehicles had these cranks?
A:
Fordman75 wrote:There are no specific models they were used in. They came in everything from 1/2 ton pick ups to F600 Grain trucks. They only way to know for sure if the engine has a steel crank is to check the crank casting #'s. From the way I understand it Ford produced the steel cranks from 65 thru the early 70's. Then from there they used the surplus cranks here and there as needed. If they ran low on cast cranks they'd use the surplus steel ones.
If you want the best shot try to locate late 60's to early 70's F600's These had 300HD's and in that age most if not all HD's had the steel cranks. But just because it's an HD does not gaurentee a steel crank. It's pretty much hit or miss in the yard searching.
thread
SuperMag
Postby Seattle Smitty » Thu Jan 17, 2008 10:08 pm
What happened to whacking the crank with a big brass hammer and see if the crank rings (forged), or clunks (cast)?
"A woman is only a woman, but B Stock Hydro is a Ride!
Seattle Smitty
Postby American Thunder » Sat Mar 01, 2008 5:23 pm
Fords crankshafts are tough, even the cast iron ones. :)
1977 530hp 302 Mustang II videos:
Smokeshow at 8000 rpm
0-90 mph speedometer view
1983 4x4 Bronco - '95 300 converted to carb, 5-speed, 3.55 gears and 9" rear.
American Thunder
Postby American Thunder » Sat Mar 01, 2008 5:24 pm
Seattle Smitty wrote:What happened to whacking the crank with a big brass hammer and see if the crank rings (forged), or clunks (cast)?
You can just look at the "seam" lines, cast iron is a thin line, forged steel is a wider line.
American Thunder
Re: Here's the 300 forged crank "casting" number.
Postby Panama Ron » Sat Jan 30, 2010 1:45 pm
If were getting 100,000 miles plus from motors with cast cranks,than Id say a forged crank would be only for a real modified race motor right? Id still like to have one in my 300 scratch re-build.
First 300-6 Ford Ive ever owned,But lots of others.
Panama Ron
Users browsing this forum: Google [Bot] and 3 guests
cron
