bigfordsix wrote:I drive my truck up a ramp placed on the rear tank side of my truck.
Thats whats nice about the old engines, they run like camel excrement its either in the ignition, or fuel system. And theres only 4 things in each system
Ronbo wrote:I think the pumps may have changed a bit. Forget the Stang and even on the Bronco I can't go full tilt. I dont put the nozzle all the way in and that helps some. I'm not sure if its the pressure/volume or just something as simple as the curve of the nozzle. You are not alone my freind
Ron
4x4xFORD wrote:So, I took the filler pipe out the other day, and no plastic tube. There is just a metal "channel" on the interior of the pipe, and the metal flapper like you see on most old school vehicles. Wrong filler pipe? Missing the plastic tubing? Dunno....
AbandonedBronco wrote:4x4xFORD wrote:So, I took the filler pipe out the other day, and no plastic tube. There is just a metal "channel" on the interior of the pipe, and the metal flapper like you see on most old school vehicles. Wrong filler pipe? Missing the plastic tubing? Dunno....
That's exactly how mine was, but had the plastic vent tube. It may be missing, and causing your barf problems.
4x4xFORD wrote:
See, that's the weird thing, I have a 66 Stang, and it will take fuel as fast as you can feed it! That's why the F150 perplexes me.
Users browsing this forum: Google [Bot] and 3 guests
