How crazy am I?
How crazy am I?
Postby goodsteel53 » Wed Mar 11, 2009 3:43 pm
My 240 block is completely shot, so I'm in the market for either a 240 or a carburated 300. Found one fairly clean in a junk yard that hand turns by the crank for $150 on my pallet. Will it bolt up to my original 3 speed bell housing, and will my starter and manifolds from my 240 interchange? Motor mounts the same? It's been years, but I can do this!
goodsteel53
Postby cdherman » Wed Mar 11, 2009 8:50 pm
So you found a 300 and you are asking if it will bolt up to the bell that your currently have with your 240? In a word, yes. The blocks are the same, except when they switched to EFI, as which point the fuel pump boss was no longer milled.
So unless they are selling you an EFI 300 (4.9) you should be golden. Starter etc all are identical.
'65 F100 240, swapped to C4, Autolite 1101, Pertronix
cdherman
Postby goodsteel53 » Thu Mar 12, 2009 10:23 am
thanks much cdherman! I'm about to head over to do the deal this morning. The motor has a carb (not sure yet which one, but NOT a single.. I have one of those by Ford on my 240). I did notice the distributor appears to be different than my points/condenser model, and doesn't have the usual two flat metal clips holding the cap down. Electronic ignition? Also.. the head has six allen bolts screwed into the top of the head at angles, like injectors might have been there (on the passenger/carb/manifold side). Is it possible to take an EFI 300cid, and convert to carb? I feel like a kid again!
goodsteel53
Postby AbandonedBronco » Thu Mar 12, 2009 11:32 am
The 300 doesn't have a 1bbl carb? If not, then it's aftermarket and someone has done some work to the engine in one form or another. The stock 300 came with a 1bbl Carter the same as the 240.
It's possible they put an aftermarket distributor on there as well (guessing).
Also, you can both convert an EFI 300 to carb, or put an EFI head onto a carb engine to gain some compression. If so, you're already getting an engine that's had some work done! :)
1981 Ford Bronco 300. 3.00 final drive, 4 speed OD manual. 4bbl Holley 390 w/Offenhauser DP Intake. EFI manifolds and 2.5" exhaust.
Sixes owned:
1957 Chevrolet 150 Sedan 235ci I6.
1987 Toyota Supra Turbo 183ci I6 (3.0L)
1981 Ford Bronco 300ci I6.
Never owned a V!
AbandonedBronco
Postby Ronbo » Thu Mar 12, 2009 11:37 am
The allen heads are more than likely plugs for the AIR that was removed. Like was said, if it doesn't have a 1BBL its been modified.
Ron
83 Bronco, 300, SROD, 32.5 X 11 BFGs, headers, Offy DP w/ Holley 390, MSD box, soft top
68 Mustang, power drums/steering, AC, single outlet coated header, DGES, DS II w/Accel super coil
2008 Pathfinder
Ronbo
Postby goodsteel53 » Thu Mar 12, 2009 4:47 pm
I own it! It's being taken out of a 76 F100, and put in my wifes "Chevy truck" to bring home in a few days, for $150. I took cell phone pics today as my digi has dead batteries! I'll post pics for ID help. Ron... "AIR" removed? I don't know that acronym.
goodsteel53
Postby AbandonedBronco » Thu Mar 12, 2009 4:52 pm
goodsteel53 wrote:I own it! It's being taken out of a 76 F100, and put in my wifes "Chevy truck" to bring home in a few days, for $150. I took cell phone pics today as my digi has dead batteries! I'll post pics for ID help. Ron... "AIR" removed? I don't know that acronym.
Was it originally from the '76?
The AIR was an emissions air injection system that was added in later years. It was a long pipe that ran the length of the engine and ported air into each cylinder exhaust or something like that. My '81 was too old for it so I don't know exactly how it works. However, if it was in a '76, it obviously didn't need it and was deleted.
Awesome deal on the engine. $150? I'd take it. I spent twice that on just the intake/carb setup I'll be putting on soon.
Sixes owned:
Never owned a V!
AbandonedBronco
Postby American Thunder » Thu Mar 12, 2009 5:59 pm
Just make sure the 300 junkyard motor has less than a couple million miles on it, and it should run great.
1977 530hp 302 Mustang II videos:
Smokeshow at 8000 rpm
0-90 mph speedometer view
1983 4x4 Bronco - '95 300 converted to carb, 5-speed, 3.55 gears and 9" rear.
American Thunder
Postby goodsteel53 » Mon Mar 23, 2009 1:04 pm
Got the 300 home and stored! Just pulled the 240 out yesterday, and plan on getting the new one in this week. Seller says he accidently left the clutch housing assembly on the flywheel, and would like it back. What would be a fair offer for it? I've made 4 trips out to his yard, and don't mind sending him the money. I've got pics of everything so far... is it not possible to directly post/attach pics to this reply. Oh.. the carb IS a Carter YF.
goodsteel53
Users browsing this forum: Google [Bot], oldbrokrcowboy and 2 guests
cron
