300 HIPO wrote:I think the max HP is produce at 4,500....
FlareSide wrote:....
By the way, making a 300 turn more rpm is silly. It's a low revving motor. More rpm doesn't mean more power. In this case, it means broken parts.
Lazy JW wrote:FlareSide wrote:....
That will be news to 6re6 (The Frenchtown Flyer).
Joe
Thats whats nice about the old engines, they run like camel excrement its either in the ignition, or fuel system. And theres only 4 things in each system
FlareSide wrote:Lazy JW wrote:FlareSide wrote:....
Joe
If a 300 makes 140 horse at 3K, why would it make more power just because it turns 6K? There's no power up there. Nothing but noise.
willowbilly3 wrote:Run this through the rpm calculator. 100 mph, 3rd gear on a T18, 3.73 gear and 31" tall tire. Done that. Gotta be 6 grand I'm thinking.
FlareSide wrote:If a 300 makes 140 horse at 3K, why would it make more power just because it turns 6K? There's no power up there. Nothing but noise.
81f100 wrote:when i do build mine will i need to put stronger valve springs in it to hold the more rpm's????
StrangeRanger wrote:willowbilly3 wrote:Run this through the rpm calculator. 100 mph, 3rd gear on a T18, 3.73 gear and 31" tall tire. Done that. Gotta be 6 grand I'm thinking.
Figure those tires at 680 revs/mile so with a 1.69:1 3rd gear you're turning:
680 x 3.73 x 1.69 x 100/60 = 7144
Which is just plain abusive for no purpose whatsoever.
Lazy JW wrote:Methinks the valve train "may" have issues somewhere south of 7100 rpm (valve float, anyone?)
Luckyman wrote:in stock form 4500 max but after 3000-3500 all you are making is noise.
StrangeRanger wrote: The valve stems are only about 1.91" center to center (tape measure, no caliper handy)
THE FRENCHTOWN FLYER wrote:StrangeRanger wrote: The valve stems are only about 1.91" center to center (tape measure, no caliper handy)
On a canted valve Boss head?
Also, on my crossflow head I moved the valve guides.
StrangeRanger wrote:Those "dastardly long" runners are tuned promote high volumetric efficiency at low RPM. Remember it's a dry flow intake. There's no gasoline to settle out and cause problems, just air.
300Straightsix wrote:that is the gross rated power
80broncoman wrote:StrangeRanger wrote:willowbilly3 wrote:Run this through the rpm calculator. 100 mph, 3rd gear on a T18, 3.73 gear and 31" tall tire. Done that. Gotta be 6 grand I'm thinking.
I'm about to call BS on that. NO not the math. just on the fact a stock 300 made it to 7100rpm ??
J.R. wrote:The stock 300" BB6 similarly has a useful, but fairly narrow RPM range, at which it delivers close to its maximum torque. Swapping to a longer duration cam would kill off some of the engine's low RPM torque, in exchange for a producing a little more, higher up in the mid-RPM range, as well as more horsepower up there. That might be the way to go if the hypothetical "triple-300" BB6 was mated to a tight 5 or 6-speed automatic trans. Hope to find out
J.R.
SoCal
American Thunder wrote: Against a 302 of equal hp, since the displacement is also equal, I would bet on the 300, but the larger 351.. not sure.
p.s. I'm not a big fan of 351W. I'd take a stroked 302 anyday.
Don't forget spark,( ignition).4x4xFORD wrote:What everybody else has been saying... Hotrodding is hotrodding, whether it be a bent 8 or a straight 6.More airflow equals more power, just at higher RPM's..........
Users browsing this forum: Google [Bot] and 3 guests
