Anybody have pics of.....
Postby 4x4xFORD » Mon Mar 16, 2009 5:56 pm
....a Carter YF/stock intake/EFI manifolds setup? Just curious....
85 F150 std. cab 4x4, Carter YF, EFI manifolds, DS/GM HEI ignition, granny 4-spd., 4" lift, 35" BFG M/T's, blah blah...
4x4xFORD
Postby cougeuph » Tue Mar 17, 2009 8:38 am
I would like to see how AbandonedBronco managed to keep all the emissions crap on his.
1980 F-250 Supercab
Engine: 300
Color: Brown Metallic
'Pops' 1970 Galaxie 500 2dr hardtop fastback coupe, 351W, FMX
'Jolly' 1970 Galaxie 500 2dr hardtop formal, 351W, FMX
cougeuph
Re: Anybody have pics of.....
Postby shmoozo » Tue Mar 17, 2009 2:13 pm
4x4xFORD wrote:....a Carter YF/stock intake/EFI manifolds setup? Just curious....
I went through my entire collection of Ford 300 six images (almost 500 images at last count) and didn't find one. Not even one.
Weird.
"Every normal man must be tempted at times to spit upon his hands, hoist the black flag, and begin slitting throats."
-Henry Louis Mencken
shmoozo
Postby 4x4xFORD » Tue Mar 17, 2009 4:31 pm
Weird.
I agree. Anyone? Bueller?...
4x4xFORD
Postby American Thunder » Tue Mar 17, 2009 7:15 pm
Does my motor qualify?
1977 530hp 302 Mustang II videos:
Smokeshow at 8000 rpm
0-90 mph speedometer view
1983 4x4 Bronco - '95 300 converted to carb, 5-speed, 3.55 gears and 9" rear.
American Thunder
Postby 4x4xFORD » Tue Mar 17, 2009 9:43 pm
sure do! :) anymore?...
4x4xFORD
Postby 56mulberry » Wed Mar 18, 2009 9:20 am
here is mine--stock intake, EFI exh mani's, Carter YF w/ a custom carb spacer and vacuum port.......on 1977 F-100
http://s300.photobucket.com/albums/nn40/56mulberry/?action=view&current=ImportedPhotos00002Small.jpg
"If you ever buy a battery at a place that advertises "free installation" and you own a 2004 Pontiac Montana, go ahead and take 'em up on the offer--while they install it you can go write a novel or solve the world hunger issue or grow some dreadlocks or something...."
56mulberry
Postby AbandonedBronco » Wed Mar 18, 2009 9:53 am
Not pictures exactly, but here's an exhaust video I took of mine that should get you a few different angles.
http://www.youtube.com/watch?v=sHTK3Twq2Vo
1981 Ford Bronco 300. 3.00 final drive, 4 speed OD manual. 4bbl Holley 390 w/Offenhauser DP Intake. EFI manifolds and 2.5" exhaust.
Sixes owned:
1957 Chevrolet 150 Sedan 235ci I6.
1987 Toyota Supra Turbo 183ci I6 (3.0L)
1981 Ford Bronco 300ci I6.
Never owned a V!
AbandonedBronco
Postby American Thunder » Wed Mar 18, 2009 7:43 pm
4x4xFORD wrote:sure do! :) anymore?...
I have since bead blasted, primed and painted that ugly ass air cleaner satin black. I got the cleaner assembly for free, and other than the paint, it was in flawless condition, so I cant complain.
I converted the '83 truck to use the '95 serpentine belt system, which is nice, minus the smog pump. I shaved down the one mounting bolt head and rerouted a shorter belt around the alternator pulley. I also converted the '83 divorced voltage regulator to the 1 wire '95 alternator setup, which is nice, too.
I put an a/c compressor from a fox body mustang on there, too.
Isnt it interesting to see the carb air cleaner, the serpentine belt system, and the '72 points distributor all under one hood?? :D
I love the look of this cast iron paint I used on the intake. Now I can't recall the exact name of it from the paint can.. bah "Cast coat" maybe?
oh yeah, my fancy bead blasted clear coated timing cover! haha
Last edited by American Thunder on Thu Mar 19, 2009 6:36 pm, edited 1 time in total.
American Thunder
Postby American Thunder » Wed Mar 18, 2009 7:48 pm
Oh, and I don't have a pic, but I used the '95 EFI throttle cable, too, because the original '83 cable snapped a few weeks ago.
The '95 cable is a bit longer, which is good, because it makes a bigger loop, which means less strain on the cable. I cut the top off the old throttle bracket, and welded on the top piece of the '95 bracket, so the cable could just snap right in the hole. It works sweet. The end that connects to the throttle pedal is the same as the original, too.
Edit: OK, I took a pic just now anyway.
American Thunder
Postby cougeuph » Thu Mar 19, 2009 5:54 pm
American Thunder.
What air cleaner box is that? i.e. what was it originally off of
1980 F-250 Supercab
Engine: 300
cougeuph
Postby AbandonedBronco » Thu Mar 19, 2009 5:59 pm
cougeuph wrote:American Thunder.
I think starting in 82(?), the 300 came with a much larger air filter. I think it went from an 8" to a 10" or 12".
Sixes owned:
Never owned a V!
AbandonedBronco
Postby American Thunder » Thu Mar 19, 2009 6:31 pm
If I recall, it came off a '84 or '85 F150.
American Thunder
stock intake/carter/efi exhaust
Postby econovan » Fri Mar 20, 2009 8:04 pm
I'm planning the same combo for my van but have some questions.
How do you supply heat to the carb like the heat valve in the stock exhaust manifold does?
What's the recommended muffler setup for two exhaust pipes?
econovan
Re: stock intake/carter/efi exhaust
Postby American Thunder » Fri Mar 20, 2009 9:53 pm
econovan wrote:I'm planning the same combo for my van but have some questions.
I don't have any intake heater on it, and it's a pain in the cold weather, because it hesitates a lot for the first 15 minutes of running it. In the warmer weather, it's not an issue. If I had the intake on the bench, I would weld up a watertight heater box and bolt it to the underside of the intake, where the exhaust manifold used to attach, and plumb it to circulate engine coolant.
American Thunder
Postby AbandonedBronco » Sat Mar 21, 2009 11:50 am
An easy way to get heat to the intake is to plumb coolant up to it. This is usually done by making a plate that bolts to where the exhaust used to go, and then having an in and out pipe fitting made into the plate. Do a quick search for Harte3 on here, he has pictures of his setup and has posted pictures to it many times. It works great.
Sixes owned:
Never owned a V!
AbandonedBronco
Postby econovan » Sun Mar 22, 2009 1:11 am
Thanks guys,
where can I get this heater plate?
And what kind of mufflers are there to get the two pipes in and out?
econovan
Postby 66 E100 Pickup » Sun Mar 22, 2009 1:50 am
Thanks guys,
Friend, you will have bigger issues than the heater plate. The EFI exhausts won't fit in the early econo DH. The front one points smack into the DH wall.
You can however, run Clifford headers, as Clifford used the econoline for the pattern on their 53-0015 shorty headers.
The heater plate, just take a 1/4" steel plate, weld in a couple fittings, and plumb into it.
What engine do you have?
John
66 E100 Pickup
Postby econovan » Sun Mar 22, 2009 10:01 am
a 300
econovan
Postby Rusty Shackleford » Sat Mar 28, 2009 8:36 pm
Hey 56Mulberry that spacer looks great! Did you have it CNC'd up? I'm in the process of ditching the feedback on my 85 and I'd love to avoid putting the egr back on, but I still need height provided by it. Nice job though, looks like it took some time and effort but it shows. :D
1985 F 150, 4 mismatched rims/tires, one fender flat black primer, surface rust covering the rest of the missing paint. My Pride and Joy.
Rusty Shackleford
Users browsing this forum: Google [Bot], oldbrokrcowboy and 2 guests
cron
