lifted 88 driveshaft
Postby IndianOutlaw72 » Wed Apr 15, 2009 8:51 pm
i kno this might sound stupid but i was wondering if i am putting a 6in suspension lift on an 88 f150 4x4 do i have to get a longer driveshaft? and is there any alterations that have to be made that are not included in the kit?
IndianOutlaw72
Postby optikal illushun » Wed Apr 15, 2009 9:25 pm
shouldnt need an extended driveshaft but it wouldnt be out of the realm of possibility as every truck is different.
other provisions? just be sure to get a front end allignment after.
1993 F-150 XLT 4x4 RCLB
Modded 300/Built E4OD
- SAS in progress
- Crane cam
- Hedman headers
- Ported intakes w/ 351 TB
1988 F-350 Custom 4x4 RCLB
7.3IDI/ZF 5 spd
- RayWel lid w/ Opti'ized ram air
- "G" codes & 1 1/2 flat up
- True 2 1/4" duals w/ packs
- 315/75/16 PC Xtreme ATs
optikal illushun
Postby THE FRENCHTOWN FLYER » Thu Apr 16, 2009 11:43 am
Re set the pinion angle if you want the u-joints to live long.
Postby crash-harris » Thu Apr 16, 2009 1:07 pm
Or use lift springs instead of blocks and/ shims from broncograveyard.com
Bruiser - 1990 Ford F150...barely...EFI 300 Big Six, nearly 300K and strong, Converted to 4x4, Undergoing 3/4 Ton SAS. 4.10 gears and Sterling Semi-Floating rear w/ Trac-Lok. [Turbo 300] build waiting on money as well...
Plans are changing again! Possible D60 Coil swap on the front end!
My girlfriend understands...:lol:
crash-harris
Postby willowbilly3 » Thu Apr 16, 2009 8:40 pm
Say no to 6 inch blocks on the leafs. Lift it right.
Great ideas have always encountered violent opposition from mediocre minds
Albert Einstien
willowbilly3
Postby American Thunder » Fri Apr 17, 2009 11:35 pm
My '78 bronc has a 6" skyjacker suspension lift. New high arch 6-leaf rear springs and the front coils are freekin long. I'm hoping I can use the stock rear driveshaft, as the slip coupling has quite a bit of travel.
I just added a 3" body lift too, and my 5'6" wife can just barely reach in to pull the tailgate latch. Wait'll she tries it with the bigger tires.. haha
1977 530hp 302 Mustang II videos:
Smokeshow at 8000 rpm
0-90 mph speedometer view
1983 4x4 Bronco - '95 300 converted to carb, 5-speed, 3.55 gears and 9" rear.
American Thunder
Postby TCIC 300ci superbeast » Sat Apr 18, 2009 11:50 am
my friends got a 78 f150 stepside 6" lift stock drive shafts.... there just about to the end of there slip or where we feel safe with it.
1978.5 f250xlt ranger custom super-cab 4x4 "superbeast" turbo300/ZF S542/BW1350/np205d dana 44HD/dana60
dec.1978 f150xlt custom 4x4 "six shooter" parts truck for super beast
2004 2.0 dohc 5speed focus DD "toycar"
truck club OHIO MUD SLINGERS
walk softly and carry a big six
Location: yellow springs ohio just south of springfield and just east of fairborn
Postby willowbilly3 » Sat Apr 18, 2009 1:51 pm
Are you dropping the front beam mounts too? Pitman arm?
Albert Einstien
willowbilly3
Postby TCIC 300ci superbeast » Sun Apr 19, 2009 8:49 pm
you have to drop at lest the pivot points or your wheels will be runing on the side walls.. and i think with over 6" lift youll need to drop the radius arms as well.
Postby IndianOutlaw72 » Wed Apr 22, 2009 8:58 pm
well i was hopeing to keep the stock leaf springs because they have the aux. springs and the kit comes with drop brackets for radius and axel pivit and a drop pitman arm and i believe 4in blocks so i might jus go with the 4in susp. and mayb a little body lift then because i did want to try keeping it simple, in a d.i.y. sense.
IndianOutlaw72
Postby TCIC 300ci superbeast » Wed Apr 22, 2009 10:07 pm
body lifts are crap...wires, lines, and linkages are stretched. all my friends that have gone body lifts have had problems with it.
Postby IndianOutlaw72 » Thu Apr 23, 2009 7:54 pm
superbeast- i see you have a larger ford, is there any lifts or is it just tires?
IndianOutlaw72
Postby TCIC 300ci superbeast » Thu Apr 23, 2009 9:10 pm
my f150s got 3" lift with progressive coils up front and 3" block out back on 38.5
my f250 will be 8" of lift with 37 to 39.5. 8" leafs up front and and 3" leafs out back with about 3-6" of block.
Postby American Thunder » Mon Apr 27, 2009 7:44 am
:D
American Thunder
oops, double post
American Thunder
Users browsing this forum: Google [Bot] and 3 guests
cron
