If your block is decked 50 thou, it would loose 50 thou space. The dual and triple pulleys are a different size. and offset. If the water pump , water pump pulley or crank pulley differ from OEM spec, then, yeah, a 3/16" spacing could become way less.
There is also a change from 4 bearing 170's to later 200's in pulley to front cover spacing.
Really? It fit's/works or it doesn't. You buy something for a falcon six it should work. If it always doesn't then it should come with what makes it work. I hope that's not the case. Sure we can make things work and yipee
I just ordered billet water pump pulley from Matt. Unfortunately he's out til the 10th. So I'll be waiting. W/p pulley diameter is an inch smaller, and less deep.
