chad":1smwgwt3 said:don't all 4 interchange (no-go w/ the 2 big six, tho?).
chad":1r85q9pb said:"…hold the distributor vacuum tube…." for LOM/SCV hose?
Ahhh, OK, thought ones I saw might B 4 throttle cable…
(No LOM/SCV here).
lahti35":188gcg5z said:http://www.ebay.com/itm/1968-Power-...ash=item4afdd61ee3:g:yAsAAOSw4T5XHX0Y&vxp=mtr
These type are the only ones I can think off that have a bracket on the right side of the cover but its not for the throttle cable... that had its own bracket that ran from the coil mounting bolts up over the valve cover and then bolted to the inner carb base flange stud. It was a "J" shaped piece of metal with a raised groove running the length.
