Hi, I have no problem doing what econoline said, adjusting solid lifters on a running engine, I have done that myself, or using a go-no go feeler gauge. Most mechanics have a way they prefer and get good results. I set solid lifters on a warm engine with a plain KD 161 feeler gauge not running. I find the engine running, pumping oil, and all the movement to be a distraction on solid lifter cars. I work on solid lifter cars with the engine off, once and done. On hydraulic lifter cars with the engine running, just tight enough to quiet them down. I like to go over each rocker, gently loosen until it clicks, and gently tighten until it quiets, maybe twice over. Some mechanics will attach a vacuum gauge. If you tighten too much the vacuum gauge and engine will flutter, although the engine may stabilize after a couple of seconds. You will get a feel for what makes your engine run best. Good luck
