Hello All, I'm putting my 144 back together and want to get a new damper (harmonic balancer). The Mac's Auto website is only showing one, fitting all 60-77 sixes. They used to show a separate one for the early 144's and 170's like mine. Will the "newer" one work?
Second, I put a new brass T-fitting (from Falcon Parts) on my master cylinder. I've tightened it as far as I can to where it still lines up with the brake lines, but I get slight seepage. Question: Can Teflon tape be used on this fitting? Would a washer possibly be the answer? Thanks
