EGR 1996 F150
EGR 1996 F150
Postby 96F150 » Wed May 24, 2006 7:42 am
making a new thread, since noone replied to my question in another EGR thread.
reading here, i see that it would be better for me to just fix my EGR valve.
i've been having a CEL come on and off for over a month now. i had it scanned and the slip said "EGR flow exceeding". the truck was scanned with the ignition on, engine off.
would a bad EGR valve set off that code, or is there something else down the line that would cause that code to show? how do i check to see if the EGR valve is good or bad? i just don't feel like dumping 60-70 dollars and the problem/code not clear up.
thanks.
1990 F150 XLT Lariat 300 L6 M5OD 8.8.
"In every man's mind, there must be a little madness, to protect the sanity of his soul." MTD 1982
96F150
Postby ordodraconis » Wed May 24, 2006 9:50 am
on fuel injected modles its always best just to fix that way when you go and test your truck it dosent throw that code anymore. on my 87 150 before it died i replaced an it actually ran alot better
1987 FSB 351w. getting ready to swap a personalized Big Six in. 32s and 4.10 C6 tranny.
ordodraconis
Postby The Plankster Prankster » Wed May 24, 2006 12:51 pm
the first thing i would do before throwing $$$ at it is take off the egr valve and clean it, it could just be dirty and thats causing it to stick open. if that fails, probably get a new valve
83 F250 flatbed 300-6, NP435, 4X4, 5800lbs empty weight
87 E-350 6.9 diesel, c6, 3.55s, powertrax no-slip locker, onboard 120v power and compressed air, built out with toolboxes and toys
Postby 96F150 » Thu May 25, 2006 12:24 am
where is the EGR valve? i see a coupla valve lookin things up top. here's a coupla pics. can someone put an arrow pointing to it? i can get closer pics if needed, just let me know. thanks.
96F150
Postby The Plankster Prankster » Thu May 25, 2006 12:22 pm
i see a bunch of covers and hoses, but wheres the engine? :lol: :lol: :D
well i cant see jack in there, but it should be right below the throttle body. itll be the only thing on the intake that has exhaust attached to it. maybe a closer look around the intake manifold might help
--josh
Postby StrangeRanger » Thu May 25, 2006 12:43 pm
There's a steel tube coming out of the rear exhaust manifold. It runs up and across thr top rear of the engine and connectd to a valve on the upper intake just downstream of and to the rear of the throttle body. That is your EGR valve. You'll need a replacement gasket if you pull it off to clean it.
StrangeRanger
Postby wolfdog » Sun Dec 03, 2006 8:50 pm
I believe that would be your egr. Im in the process of removing all my emissions from a 300 i6 also.
wolfdog
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
