best 300 transmission
Postby 32sedan » Mon Jan 25, 2010 11:14 pm
I was wondering what transmission would be the best to put behind my 300 considering i am also looking at puting a gear vender behind it. I had my engine dynoed yesterday and it is close to 750 ft/lbs but at only 550 hp. actual ft/lb was 726 but as i said thats close to 750. I'll tell you my engine does have forged 300 flat tops i got from venolia pistons and i'm running a Aerocharger at 10 psi and running it through a powerjection 3 efi carb . engine was complete balanced before i built it and at the dyno it seems to me excetionally well balanced. once again i'm tahanking you in advance for your responses.
32sedan
Re: best 300 transmission
Postby Lazy JW » Mon Jan 25, 2010 11:24 pm
To what use will this be put? Circle track, drag racing, mud bogging, trailer towing?
74 F-350 300-6, EFI manifolds into single exhaust, Carter YF, T-18B, Dana70 w/4.11, Flatbed dually w/dump bed. Great farm truck!
Lazy JW
FSP Moderator
Postby THE FRENCHTOWN FLYER » Mon Jan 25, 2010 11:24 pm
A 1.76 Powerglide. Good for 1000 HP.
Postby Harte3 » Tue Jan 26, 2010 1:53 am
Got pics?
Harte3
Postby 32sedan » Tue Jan 26, 2010 2:27 am
it's gonna be a street rod. engines going in a 41 ford pickup with both independant front and rear. the front and rear is out of a mustang cobra . mostly road cruising but ocasstionally might haul a trailor.
32sedan
Postby Thad » Tue Jan 26, 2010 11:01 am
Lentech built AOD, can handle the torque and no need for the Gear Vendor OD. Perobably cheaper than built P'glide with bellhousing adapter and GV set-up, AOD more compact.
There are those who just dream,
and there are those who do more than dream. ><> = +
Thad
FSP Moderator
Postby 32sedan » Tue Jan 26, 2010 12:07 pm
only reason i'm looking at the gear vendor is for added insurance and and some gas milage.
32sedan
Postby F-250 Restorer » Tue Jan 26, 2010 2:01 pm
About a year ago, when I was shopping for a trans for my truck, I contacted TCI and another one of the AOD builders. They both said the same thing: If you are ever towing a trailor in the hills/mountains, an AOD can't handle it, and you would be better off to go with a C6.
A beefed up C6 with a Gear Vendor over/under drive is bullet proof.
F-250 Restorer
Postby 32sedan » Wed Jan 27, 2010 8:48 pm
how bout a beefed up E40D i was told if built up right they are suppose to be real good don't know a c6 and a gear vcender would give you basicly a 4 speed yes i mean it would 6 but with the 6 gear would actually make a 4 with overdrive thats why i say and E40D. anyone have any input on this perticular tranny.
32sedan
Postby Panama Ron » Thu Jan 28, 2010 12:54 pm
Thats a lot of power/torque,please tell us how you built the motor,what parts did you use,crank,rods cam,ect,ect,
I like it already, Pics???Please.
First 300-6 Ford Ive ever owned,But lots of others.
Panama Ron
Postby 32sedan » Thu Jan 28, 2010 4:02 pm
bought 96 block got a carbed head ported polished 1.94/1.60 valves 10 to 1 flat top forged venolia pistons, aerocharger turbo with 10 psi , powerjection 3 from retrotek speed, custom ground roller camshaft and roller rockers 1.73 ratio. efi exhaust manifolds with solid pipe conection between them that then goes to aerocharger i'd come close to say that theres no lag in turbo doing it that way either. 2.5 inch pipe out of turbo to Aero Turbine 2.5 in out muffler to y pipe then x pipe duals out the rear. thats all that i can remeber just off the top of my head. pics will be hard to get scince i have no digital camera. the problem i got now is find a good automatic tranny to hold up to it without paying a fortune for it.
32sedan
Postby StrangeRanger » Thu Jan 28, 2010 6:56 pm
The E4OD shares a lot of its guts with the C6. it's not quite a C6 with an OD grafted on but it's close. However the E4OD requires a powertrain computer in order to operate. you can buy a standalone controller from Baumann http://www.becontrols.com/products/electronicscat.htm but it has some limitations. The C6 with an add-on OD is probably a better bet than an E4OD in a non-EFI application. Have you looked at the US Gear OD? It's a bit cheaper than the GearVendors, with a bit less functionality. http://www.usgear.com/v2od.htm
1996 F-150 (tow missile)
1993 Mustang 5.0 (hot rod and auto-x monster)
1982 Tiga Formula Ford (SCCA racecar)
2013 Hyundai Elantra Coupe (daily driver)
StrangeRanger
Postby Panama Ron » Mon Feb 08, 2010 1:26 pm
Id like to do this build,minus the turbo,just the all motor build,where did you get the roller cam?from Ive been seeing here,Its hard to do because of all the machine work.Did you bore the block?
Panama Ron
Postby IllSHOyou » Mon Feb 08, 2010 3:52 pm
32sedan wrote:I was wondering what transmission would be the best to put behind my 300 considering i am also looking at puting a gear vender behind it. I had my engine dynoed yesterday and it is close to 750 ft/lbs but at only 550 hp. actual ft/lb was 726 but as i said thats close to 750. I'll tell you my engine does have forged 300 flat tops i got from venolia pistons and i'm running a Aerocharger at 10 psi and running it through a powerjection 3 efi carb . engine was complete balanced before i built it and at the dyno it seems to me excetionally well balanced. once again i'm tahanking you in advance for your responses.
Aerocharger, excellent selection! I want one for my SHO.
IllSHOyou
Postby AbandonedBronco » Mon Feb 08, 2010 6:30 pm
I'm curious how much truth there is to this, but someone was saying that the under/overdrive units will only work in the F-series trucks, and not a Bronco. Since the Bronco's so short, the unit pushed the start of the driveshaft back even further, causing it to be too short and too sharp of an angle down to the differential. Thoughts?
1981 Ford Bronco 300. 3.00 final drive, 4 speed NP-435. 4bbl QuickFuel 450cfm w/Offenhauser DP Intake. EFI manifolds and 2.5" exhaust. DUI ignition.
AbandonedBronco
Postby 32sedan » Thu Feb 11, 2010 8:16 pm
i had the cam custom ground by isky it was $650, no i did not bore it over just honed it and put 10 over rings in it wanted to leave to meat in the block that way if later down the road i have to rebuild it i could.
32sedan
Postby 80broncoman » Fri Feb 12, 2010 1:23 pm
AbandonedBronco wrote:I'm curious how much truth there is to this, but someone was saying that the under/overdrive units will only work in the F-series trucks, and not a Bronco. Since the Bronco's so short, the unit pushed the start of the driveshaft back even further, causing it to be too short and too sharp of an angle down to the differential. Thoughts?
Yes I think the gear vendors unit is a bit long for what it does.
but wherater or not it fits wouldn't it depend on what trans you are running?
If you have a T18 and a shorter trans/Tcase adaptor I'd think you might be able to squeze one on a bronc.
Have these people ever seen a Auto trans CJ-7 drive line? or any CJ-5 driveline?
OAPSE Union Member
Real men don't wear Bowties
80broncoman
Postby 32sedan » Tue Feb 16, 2010 7:55 pm
someone local has suggested a manual tranny instead of an automatic is there one that can handle that much torque.
32sedan
Postby StrangeRanger » Tue Feb 16, 2010 8:40 pm
http://www.g-forcetransmissions.com/tran_gt-56.asp
But it's a tad expensive. I have one of their T5 conversions in my 5.0 Mustang. Big teeth, low helix angles, a tad noisy but bulletproof at my power level.
The Tremec TKO CR box is rated at 600 ft-lbs continuous. I don't know what that means in peak numbers though
http://www.ttcautomotive.com/English/products/TKO.asp
StrangeRanger
Postby Buddy Rawls » Wed Feb 17, 2010 2:07 pm
n/a
It doesn't run quick at the track, but it gets long stares wherever it goes.
Never in a million years did I think I would have an antique hot rod truck, much less with its own name emblazoned on the front fender and a freakin' six cylinder for power;
but it is a Ford, it is old, and it is definitely one of the funnest vehicles I have driven.
Buddy Rawls
Postby 32sedan » Wed Mar 03, 2010 4:24 pm
i've been told i might coul us a ZF S547 or posibly the T18/T19 with a gear vendors unit to handle my engine is there anyone whom might could tell me if this is true or not.
32sedan
Postby 32sedan » Tue Mar 16, 2010 8:27 pm
i take it no one used this as far as a Zf s547 manual transmission
32sedan
Postby StrangeRanger » Tue Mar 16, 2010 8:37 pm
It's rated for 470 ft-lbs continuous, don't know about peak but it's a very wide ratio box to try to use in a car
StrangeRanger
Postby Ferris Bueller » Tue Mar 16, 2010 9:31 pm
How about buying a 6 speed manual from a newer F250/F350 and then buying an adaptor to mount the transmission to your 300?
White 09 Ranger 2wd 2.3 5sp 143hp 3.73 60k miles
White 04 Ranger 2wd 2.3 5sp 143hp 3.73 134k miles
Ferris Bueller
Postby StrangeRanger » Tue Mar 16, 2010 11:09 pm
It's huge and unbelievably heavy plus it requires an external oil cooler just like an automatic. AFAIK no one makes an adaptor. The ratios are not right for a car either.
StrangeRanger
Postby 32sedan » Wed Mar 17, 2010 2:24 pm
it's not going in a car it's going in a 41 ford pickup that already had a manual in it
32sedan
Postby 32sedan » Wed Mar 17, 2010 2:26 pm
i was also trold by a guy at ford that the Zf s547 would hadle 780 ft pounds because it was also made to work on the desiel trucks which if built right can easily get that number
32sedan
Postby StrangeRanger » Wed Mar 17, 2010 2:45 pm
The code for ZF trannies is
S542 = 5 forward speeds, 420 ft-lbs of torque continuous
S547 = 5 forward speeds, 470 ft-lbs of torque continuous
S650 = 6 forward speeds, 500 ft-lbs of torque continuous
StrangeRanger
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 7 guests
