Crank and Cam For 300 inline 6
Postby 78FordF100Custom » Tue Apr 24, 2012 7:29 pm
I have a 1978 Ford F-100 Custom with a all stock 300 inline 6. Engine was rebuilt so it is really super clean, but I was wondering where are some sites or dealers or sellers that have a Cam and Crank for a 300. I have looked and I can't find one.
I have bought headers, four barrel intake. I am gonna swap over to a C6 Auto Trans with a 205 trans for case. and 4:11 gears front and rear. I am wanting to have a really strong and powerful engine. I just need to know of a place to get the cam and crank.
78FordF100Custom
Re: Crank and Cam For 300 inline 6
Postby Harte3 » Tue Apr 24, 2012 8:25 pm
Comp, Isky, Schneider, etc., make cams for the 300. Try Summit Racing, JEGS, etc. The stock crank is more than adequate for most modified applications.
Harte3
Postby 78FordF100Custom » Tue Apr 24, 2012 8:50 pm
what size cam would be good for the 300 if you dont mind me asking. And before you ask I aint worried about my gas bill going up at all.
78FordF100Custom
Postby StrangeRanger » Tue Apr 24, 2012 10:28 pm
The cam choice depends in part on what you're building it to do and in part on what other mods you are planning
1996 F-150 (tow missile)
1993 Mustang 5.0 (hot rod and auto-x monster)
1982 Tiga Formula Ford (SCCA racecar)
2013 Hyundai Elantra Coupe (daily driver)
StrangeRanger
Postby 78FordF100Custom » Wed Apr 25, 2012 10:27 pm
I want the and heads to be bored .30 over and heads and block shaved. I want it to be a stroker engine. I am just gonna get the case iron longer connector rods. I am gonna have a four barrel intake with a 600 carb with a 1 1/2 in spacer I want to have headers. and electric fan , fuel pump. and tran mission cooler.
78FordF100Custom
Postby THE FRENCHTOWN FLYER » Thu Apr 26, 2012 8:24 am
78FordF100Custom wrote:I want the and heads to be bored .30 over and heads and block shaved. I want it to be a stroker engine. I am just gonna get the case iron longer connector rods. I am gonna have a four barrel intake with a 600 carb with a 1 1/2 in spacer I want to have headers. and electric fan , fuel pump. and tran mission cooler.
Oh boy where to start.
I guess the good news:
The four barrel, spacer, headers, fan, trans cooler are all sound choices, as is boring the cylinders, and cutting the block and heads.
But: unless you are planning on towing 747's out onto the runway there is no need for a stroker crank, and by the way, you would not be able to fit longer rods in with a stroker crank. Factory rods are forged, not cast. The head is where you should concentrate - it is too restrictive for the engines 4 inch stroke, much less a stroker crank. Bowl work and maybe bigger valves with screw-in studs and roller rockers will all be plusses. Good luck.
Postby Harte3 » Thu Apr 26, 2012 10:47 am
The build depends on what/how you are going to use your truck which is...?
Harte3
Users browsing this forum: Bing [Bot], Google [Bot], Yahoo [Bot] and 2 guests
