93 Ford F150 Tranny Swap
Postby Susmark1 » Thu Dec 06, 2012 8:24 pm
Let me begin by saying that I am brand new in forum but have been doing some reading on here for a while... There is definately some good info!
Currently I have a 93 F150 4x4 with a 300 fuel injected and a 4 speed T18. The gears in rear are 3.55's. I do a lot of highway driving and the 75mph speed limit really is pushing the engine rpm's. Will replacing the tranny with a ZF or NV 4500 lower the rpms enough to gain any fuel mileage? I know the swap is not that cheap especially the NV swap. I appreciate the help!
Susmark1
Re: 93 Ford F150 Tranny Swap
Postby 80broncoman » Thu Dec 06, 2012 10:57 pm
Do you really need the 3.55 gears??? if you running close to stock height tires I'd think 3.08 gears would work much better for MPG.
OAPSE Union Member
Real men don't wear Bowties
80broncoman
Postby StrangeRanger » Thu Dec 06, 2012 11:19 pm
To answer the simplest question: unless you get most of the parts for free, there is no tranny swap or gear swap that will pay for itself in fuel mileage.
What tranny was in your 93 originally and how did it end up with a T-18?
1996 F-150 (tow missile)
1993 Mustang 5.0 (hot rod and auto-x monster)
1982 Tiga Formula Ford (SCCA racecar)
2013 Hyundai Elantra Coupe (daily driver)
StrangeRanger
Postby Susmark1 » Fri Dec 07, 2012 2:18 am
I don't know what was in it orginally. Traded a couple of guns for the truck and it was in it when I traded for it.
Susmark1
Postby Susmark1 » Fri Dec 07, 2012 10:22 am
as far as tires, I am running 31's on it and if it cost me some money to get it to run down the highway better, thats ok.
Susmark1
Postby Harte3 » Fri Dec 07, 2012 1:53 pm
Back off on your hwy speed to say 62-65 mph and you will get some increase in mpg. Just because the speed limit is 75 mph, nothing says one has to drive at that speed.
Harte3
Postby MechRick » Fri Dec 07, 2012 2:21 pm
If that T18 has a granny gear, you can switch the gear ratios to 3.08's.
I put a ZF in mine to set it up for towing. You will need the hydraulic line and master from the donor truck (different style hydraulic line). The trans crossmember will have to be relocated and notched. I used a C6 rear mount (lower to make up for the difference in frame heights). Front driveshaft will have to be lengthened, the rear shortened a couple of inches. Transfer case bolts right up.
Stock cam installed straight up (aluminum cam gear)
viewtopic.php?f=2&t=73244
Bronco II with a 2.3L swap viewtopic.php?f=13&t=72863
MechRick
Postby THE FRENCHTOWN FLYER » Fri Dec 07, 2012 2:34 pm
Harte3 wrote:Back off on your hwy speed to say 62-65 mph and you will get some increase in mpg. Just because the speed limit is 75 mph, nothing says one has to drive at that speed.
x2
and keep an eye on tire pressures.
Postby Susmark1 » Fri Dec 07, 2012 5:19 pm
I would like to put the ZF in. I think it might work out great. I would do all the work myself as I have a small machine shop in the garage (lathe, welder, vertical mill etc...)
Susmark1
Postby MechRick » Fri Dec 07, 2012 8:26 pm
I'm envious. I sold my vertical mill two years ago and have always wanted a nice metal lathe.
Should be a piece of cake for you. I welded up my own shafts, got them within .010" runout without a lathe, but it was a lot of work. You just need to find an F250/F350 4x4 ZF from a 5.8/5.0/4.9L truck and you are golden...
MechRick
Postby Susmark1 » Fri Dec 07, 2012 9:19 pm
Well the only reason I have those tools is to build guns but they sure come in handy when you need them. I am going to start looking and get the parts together. I sure appreciate the help!
Susmark1
Postby Susmark1 » Fri Dec 07, 2012 9:20 pm
.010 without a lathe is really good!
Susmark1
Postby tom954x4 » Sun Dec 09, 2012 4:22 pm
like what Harte 3, if you drive 75 your mileage will suffer even if you change trannys or gear ratio. Wind resistance at 75 mhp is more than double the resistance at 50 mph. This is a big deal in a aero brick like a 93 F-150.
1995 F-150 XL, 300-6, 4x4, ex-cab, sb, 3.08 5-speed, 2 1/2 in. exhaust w/flowmaster 50, MSD ignition failed with no warning, now out , canopy, 177,000 + miles Gone :bang: but not forgotten: 1965 F-100 240 3spd lwb "the green hornet"; 1960 F-250 4x4, 223 six, 4sp with wrap-around rear window, two-tone paint, overhead camper.
Tow vehicle: 2012 F-250 4x4 6.7 diesel XLT s/c lwb
tom954x4
Users browsing this forum: corradolvr, Yahoo [Bot] and 4 guests
