4.0 jeep intake on a 300 six???
Postby sdiesel » Sun Jan 20, 2013 7:00 am
this throttle body manifold from the late model jeep is, for lack of a better word, sexy compared to most
The design looks perfect for my propane needs.
Short of buying a jeep engine has anyone fooled around with a graft onto a 300 six?
here is a link to a google image.
its a looney idea i should never have posted this. the outer two intake ports appear to be siamesed which is a non starter right there.
http://upload.wikimedia.org/wikipedia/c ... gine_s.jpg
sdiesel
Re: 4.0 jeep intake on a 300 six???
Postby jack orchard » Sun Jan 20, 2013 6:36 pm
To quote you, Maybe it is a looney idea. Maybe others have a more favorable impression...jack
jack orchard
Postby StrangeRanger » Sun Jan 20, 2013 6:49 pm
At one time, when Jack was still alive, Clifford was developing an EFI system for their 4V manifold. It used an adaptor plate to mount the T/B and the tops of manifold runners were machined for the injectors. I do not know if additional metal was added to the casting to provide bosses or not. If additional metal is required, buttering 6 pads of aluminum onto the top of the manifold should be doable for any weld shop that can work in aluminum.
Mayber you can re-invent that wheel?
1996 F-150 (tow missile)
1993 Mustang 5.0 (hot rod and auto-x monster)
1982 Tiga Formula Ford (SCCA racecar)
2013 Hyundai Elantra Coupe (daily driver)
StrangeRanger
Postby 80broncoman » Sun Jan 20, 2013 8:39 pm
Both of my Jeeps (a 99 and a 06 have that intake) I think the port spacing is slighly better suited to a 144-250 however If you took a lower factory 300 EFI manifold and that 4.0 Jeep intake I'd think you make one work with a bitof cutting, grinding and welding.
That intake is Quite good on a 4.0L . Equal length runners are hard to do on a inline 6 with 1 throttle body!!
OAPSE Union Member
Real men don't wear Bowties
80broncoman
Postby THE FRENCHTOWN FLYER » Mon Jan 21, 2013 2:05 pm
Wouldn't this just be a whole lot easier with your choice of throttle bodies / plenum???
Postby jack orchard » Mon Jan 21, 2013 4:29 pm
sdiesel: I was wrong. your idea was not looney. after reading what others have written (StrangeRanger and 80broncoman), I must admit it has posssibilities. You guys are the ones who keep their eyes open and see products and methods that others (like me) do not see. As I said before, I was wrong.
FTF: That intake is beautiful! Great thinking. Is it something you make? If so, do you sell them?
Best of luck to all...jack
jack orchard
Postby 80broncoman » Mon Jan 21, 2013 10:17 pm
For multiple throttle bodys FTF's intake is defintly the bomb.
OAPSE Union Member
80broncoman
Postby THE FRENCHTOWN FLYER » Tue Jan 22, 2013 11:14 am
I did not make it. It was made by my genius machinist friend Pete - the same dude who built a 300 six powered Pinto that was quite successful. He was a designer at Ford Engine Engineering. He also has a 300 powered T-bucket roadster that he built that intake for, shown in the background of the pic.
I did some of the welding on this intake and also did the tin work on his Pinto. It was great to have a friend that I could bounce ideas off of and vice-versa. His plan was to build several different tops to try different setups. I don't think other tops were made however.
Three Rochester 2Gs would look nice on that base, no?
Postby Harte3 » Tue Jan 22, 2013 12:37 pm
The Rochester 2Gs or 2GCs are probably the most overlooked 2v carb out there and would not only look great but should perform quite well.
Harte3
Postby sdiesel » Fri Jan 25, 2013 2:13 am
i was embarrassed after sobering up and realizing what i had posted but sure it got a lot of response.
That fancy aluminum intake, what a marvel, wow!
i can see it with 2 FISH carbs on it.....
thanks for all the responses.
sdiesel
Users browsing this forum: 161henry and 4 guests
