T5 8 1/2" clutch
Trans, clutch, driveshaft, and rearend.
T5 8 1/2" clutch
Postby mustang66_200 » Wed May 31, 2006 6:26 pm
Hey guys, i've got everything needed for the install except the clutch. I'm using an 8 1/2" bellhousing from an early '66 200 manual. Do i just re-surface the flywheel (that i got from the manual donor car) and the original clutch for the V8 T5 and i'm good to go? Thanks for the help guys.
josh
mustang66_200
Postby XFlow_Fairlane » Wed May 31, 2006 8:18 pm
you will need a 4 cyl clutch (83-93 2.3L mustang with 5 speed)
I lucked out and the clutch that came with my free motor fit the T5 trans just fine (10 count spline)
the V8 clutch will be around 10" and will not fit under the pressure plate.
Rule: Torque = Fun , Turbo's make Torque
XFlow_Fairlane
Postby 64.5 TX Stang » Wed May 31, 2006 8:31 pm
Yup you need the 87-93 3.2l mustang clutch disc, and the original pressure plate. Remember to have both steps of the flywheel surfaced.
1964 1/2 Mustang
200 I6 / T5 5-speed.
Bone stock w/ DSII
64.5 TX Stang
Postby shetland » Wed May 31, 2006 9:07 pm
Does anyone know what the spec's are for the space between the steps in the 8 1/2" flyweel? what should the inset be? I have and extra flywheel and would like to check it before I have it surfaced.
65 Mustang, 200 I6, CI 264 110* cam, DSII, Offy 3x1 w/triple webbers, pacemaker dual out header, 2" dual exaust, T5.
shetland
Postby 64.5 TX Stang » Thu Jun 01, 2006 1:44 am
Alright I measured the two that I have one is 0.965 inches, and the other is 0.982 inches, sooooo I am not sure which is exactly correct, but it should get you in the ballpark.
1964 1/2 Mustang
Bone stock w/ DSII
64.5 TX Stang
Postby shetland » Thu Jun 01, 2006 2:07 pm
Thanks Andrew. I will measure the one that I have for comparison.
Maybe the better question would be, How much compression there should be on the pressure plate to minimize slipage? Is there a spec for that?
shetland
Postby 64.5 TX Stang » Thu Jun 01, 2006 2:28 pm
I would imagine that there is some spec on that, but I don't know where you would find that, maybe a Ford shop manual?
1964 1/2 Mustang
Bone stock w/ DSII
64.5 TX Stang
Postby CobraSix » Wed Jun 07, 2006 12:28 pm
Above post is correct, for a early bell housing and recessed fly wheel, you'll need the following:
85-89 4 cylinder mustang T5 clutch disc
65-66 6 cylinder recessed flywheel pressure plate
Slade
Slade
My Website
My How to's
Engine: 200 CI, Oz 250 modified for 4V Holley 390CFM, DS II Ignition, 40kV Flamethrower, MSD Digital 6+
Drivetrain: Cable Clutch, V-8 T5, 8" 5 Lug Rear End, 5-Lug SSBC Front Brakes, 3.40:1 Posi
CobraSix
Return to Transmission & Drivetrain
Users browsing this forum: Bing [Bot] and 2 guests
