if '64 U can get the later diz in (it is the break yr. Forget if it;s OK in '64 or nxt yr). Bottom hole for diz is bigger = DSII diz + carb (upgrade from SCV/LOM feedback system)..
How The Stock Load-O-Matic Distributor Works Here is a little clarification on how the "Load-O-Matic" distributor works, along with the infamous "Spark Control Valve" (or SCV). Not only is it important to know how they work, especially if your...
fordsix.com
We don't just adda cam. An auto isa system, therefor change 1 thing 1 place = effects other prts other places 2.
U build the motor around the cam U select...
U select the cam for the specific application of the vehicle.
I cant C ur lill pic but I wuz serious. Look there, guestamate'n talk to Gerry or son Kevin on th phone. Tell them the final application (...a weekend cruiser not a drag racer but I wouldn't mind a few extra horses..."). What 80% of the RPMs will B, if U will go w/the 1v or 2v carb, and octane gas it'll B fueled by (cheep stuff is 89, pep is 91 and above).
Do this thinkin & ask Qs here. Due diligence it's called, no? Then U can order, still not sure - telephone. Prt of mod is research. Even if some1 else duz the wrk U gotta no what to tell them~
