This has been SOLD!
1988 Ford Econoline clutch and brake pedal assembly. This was a 5spd equipped van with a hydraulic slave set up. This used a vertical rod that went down to a clutch master cylinder that was mounted on the floor. the first picture below shows this before it was removed from the parts van. The red arrow in the picture shows master location. This should work in any 1975-1991 3rd generation Ford Econoline van. This is just the pedal assembly, The hydraulic system is not included. I'm currently looking for the master cylinder push rod. If I can find it I will include it. But as of now it's not included.
Overall it's in good condition. Both pedals work smoothly. I would replace the pedal bushings before installing the assembly. The time to do it when the assembly is out. And the clutch master push rod pin has some slight wear but nothing horrible.
I bought this to do a manual transmission swap into my 89 E350. But that project is no longing happening. I bought a complete parts van to get this. These are not easy to find.
I'm asking $300.00. Price doe not include shipping cost. If you are interested PM me your zip code for a shipping quote. I'm located in Lonsdale, MN ( 55046 ) if you would prefer to pick it up in person. SOLD!
