I'm finally finishing the 2in front to back conversion of the stock exhaust on my '66 (had it done halfway back...waiting for long back ordered 68-70 2in headpipe). At any rate, I noticed what appears to be steel or wire mesh in the bottom of the hot air choke tube passage going through the exhaust manifold to the 1100's choke tube. I also seem to recall having seen this before. The aftermarket 2in opening manifold I'm installing does not have anything in the passage...can anyone suggest a reasonable substitute for this material that will withstand exhaust punishment?
I think the purpose of this metal/steel mesh material (looks like a tiny, tiny birds' nest) was to be a half-arse filter for the passage to keep small debris or some such from being sucked up the choke tube (and possibly to further reduce vacuum bleed there)...since the choke heater tube appears to see a constant (albeit small) amount of vacuum even after the auto choke is fully open...but this may be wild speculation on my part as to its purpose...still would like to find a suitable 'exhaust' proof piece of mesh to semi (or very limitedly) obstruct/filter the passage...just not sure what type of material to go with?
Any thoughts (EDIT: like this is just crazy talk you're asking for something to break down and clog the port) or suggestions appreciated/welcomed. Thanks again in advance.
