Any tips on removing this manifold from the head w/o breaking bolts or the head castings at the ends of the head? When installing the replacement manifold ( it uses the flat exhaust pipe gasket) how do I insure the bolts stay tight? I had this issue w/my 144 they would loosen after a year or so and develop a noisy leak.
The 200cid came this morning. The CL seller was VERY accommodating delivering it to me which is abt a 2 1/2 hour drive. And unloaded on to my little HF dolly. Worked swell! Pulled the plugs and all look pretty good sort of the dark copper color and slight shine. No black carbon incrustation. Maybe I got a good runner. Over in next few weeks will be pulling the ancillary accessories and giving the block a good scrub and blue paint.
Tnx for your help so far!
Terry
Terry
that's too bad about the damage to the 68 exhaust manifold. Thats is a good thing then that you can use the other one you have. The 1968 engine has the duel vacuum advance / retard unit its a good point type Distribitor, with some work the carb might be a match. Yes that's a good idea to replace all those block freeze plugs while the engine out and is so much easier then when it's sitting in the car. The freeze plug in back and front of the heads log usually don't need replacement as there is no water or coolent in there. Now that you have the exhaust off check out the small freeze plugs on side of head under the log too while you have good access. They are about 1 inch diameter these are really hard to do in the car without pulling off the head had one or two start leaking coolant on my 77 Maverick a few years back, big mess. Good luck
