2100 or H/W 5200
64.5 TX Stang
What are the pros and cons of each setup. I want to do a 2 barrel swap on my car, but I don't know which way to go. So any input/advice is very much welcome.
Howdy Back Andy:
This info has been posted several times. You might want to do a search on both carbs and catch up.
Both carbs have a successful track record on our sixes. Both can be mounted using an adaptor resulting in hood clearance issues. Both will do better mounted directly to a modified log. Both will need adaptation and fabrication for linkage, fuel line and air cleaner. Both have both ported and manifold vacuum sources.
In a nut shell, the pluses for an Autolite 2100 are-
*very durable, and simplier version of the Holley 2300
*Power valves from a 2300 interchange
*annular discharge venturi boosters
*no gasket line blow the fuel level.
*excellent bowl venting
*possibly the simpliest carb to rebuild- ever.
*cheap and available in many cfm sizes ranging from 190 to 424 cfm
*Low profile and light weight
The minuses are-
*no longer being produced
*jets are hard to find
*cluster design limits idle and transition tunebility(Not a big issue)
The pluses for a 5200 are-
*Progressive design for excellent mileage and improved power.
*Available new or recycled.
*Parts are available
*sizes range from 230 to 280 cfm
The minuses are-
*a more complex carb, but infinitely tuneable
For all-around performance and tuneability a 1.14 (300 cfm) 2100 on a mild 200 is hard to beat for simplicity, economy, durability and improved performance. The same can likely be said for the 5200, but the 5200 may be a little more difficult to get right to begin with and more finicky over time.
That's my two cents- for what it's worth.
Thanks for the reply David. I am leaning towards the 2100 since I would like to be able to just set it and forget it as much as possible. I had researched the topic a little, but nothing very conclusive cropped up into my field of view. Oh and how hard is it to rebuild a 5200? It's not my first carb, but I have only previously done autolite 4100's back when I was into bent 8's.
Howdy Back Andy:
I have no 1st hand experience with rebuilding a 5200. I do have the HP Book by Mike Urich. It seems to me to be pretty straight forward. You might read through the sticky at the top of this forum on jetting the 5200 and PM some of the individuals who have been down this road for 1st hand advice.
Have you done any other mods other then the DSII?
I can vouch for simplicity of the 2100 and how easy it is to rebuild.
If you are interested, I have 2-3 2100s in various sizes that I rebuilt a few years ago, but never ended up using them.
Slade
