250 install in '61 (Comet) fits ... but with a few issues :
( most were addressed in the Schjeldahl bros' book )
1) The Radiator clearance is very tight. (Looking into Pusher Fans)
2) Clutch Z-BAr is too long and it needs to be shortened in the middle. ( I'm looking for 63-65 VeeAte bar and/or the length of one.
3) Engine sits slightly higher than needed with modified "Early" Motor Mounts (Modify - lower further or use later??)
4) Bell and rear of cyl. head hit Firewall. ( Removed engine - again - and "formed" firewall further with BFH) Lowering engine will help also.
5) Two related problems - The Starter interferes with the Center Steering Link and the Link will probably hit pan if engine is lowered (Schjeldahl Bros' recommend flipping center link and re-reaming reverse taper in Idler and Pittman.)
6) Big question whether Hooker dual outs (which do fit the 250), will fit into the Comet engine bay, it looks like not. (Hookers are at sandblaster so I haven't been able to try them)
7) Electrical Sensor, Charging system and Ignition Wiring are different. (Using old Temp/Oil lites and new guages, Alternator, and Clifford re-curved DSI dizzy and GM Module.)
8) Offy/Holley 3X1 setup won't clear hood. (Thanks IMPROBCAT for the hood waiting for Teardrop Thunderbolt scoop with functional cutout.)
?What NExt...??
That's all folks...
Powerband 8)
?What NExt...??
That's all folks...
Powerband 8)
