Im just putting together another motor for my Xe Esp turbo, and i cant find information for a decent camshaft i wondering if you guy can help as i am lost.
The motor it self has 8.50 compression ratio, port and polished head, forgies.
I cant give you any exact specs, but honestly your best be would be to go and speak to a cam grinder and get a custom grind.
As there is no off the shelf cam for a turbo x-flow, you would have to decide on the cars use. eg daily driver, strip use etc. as this would virtually decide what cam suits anyways..
I have heard good reports about SureCam (QLD) grinding cams for turbo 6's. Might pay to give them a buzz.
I havde heard great thigs about sure cam. They are grinding a turbo six cam for a mate of mine now.
There is also the Mike Vine cam. Mike Vine is also in Qld. It is very mild good for street use.
I used this cam with a bigger inlet profile ground onto it.
The MikeVine cam uses a 114° lobe separation and is a new billet. The lift on exhaust profile seemed a bit big relative to the inlet so I gorund the bigger inlet profile.
