good evening. When I replaced the broken cast exhaust manifold on my 262 with a twin outlet Clifford header I banged the dipstick around a bit. When I took it out for a test drive I found I had an oil leak coming from the dipstick outer tube. I have the Ford service manual for the f250 but it says nothing about how its removed and replaced. I went to the interwebs with little info about the 262 specifically, but most other ford tubes just pull out was the consensus. I took some pics and then gave her a tug. the tube came off but left about an inch left on the block. Any advice on getting the leftover out and where to locate a replacement? any advice on this repair would be appreciated. I can find zero info on this , My assumption would be this shouldn't be overly difficult. But I'd like to have a proper plan before I proceed. Thank you. Rick
