mustangsilly
Since no one responded to my earlier question, I'll ask again.
I installed a JD roller set and am now assembling the engine. When I installed the oil slinger over the crank and tightened down the balancer and turned the crank by hand, the oil slinger catches the chain links in two places and makes a scary popping noise.
Has anyone else had this problem? Is the JD crank gear compatible with the oil slinger, or is some kind of spacer required to keep the slinger off the chain? I don't want to leave it off as I assume it serves some purpose.
Thanks for your (anyone's) help.
