Well, I decided to chuck a 3.9 injected engine into my old XA wagon.
Could be arsed with injection though, mess of wires and bollox, so I whacked a 350 holley onto an old singlepoint injection manifold.
Also cut out the water jacket and smoothed a few surfaces on the manifold, as well as opening up the plenum a little with a die grinder.
How I made this version of the adaptor, was useing a 4mm alloy plate, holesawed and drilled. The plate bolted to the manifold like the standard TB, then the fat alloy vac plate you see sits ontop, the plate bolts sit inside that, and then bolt the holley on top.
The next stainless adaptor will be made of two seperate plates and have a fairly tall oval tube inbetween.
Bugger all clearance there though, so currently making up a stainless adapter to bring the height up another 60mm. Which means, I'm gonna be cutting a hole in the bonnet.
Whats funny as hell is the engine now runs ten times better than it did injected!!!
For the distributor, I got an old xd/xe points dissy and put the EA gear on the shaft. Had to flip the gear over to match the ea dissy position and re-drill the shaft for the pin.
Full Shot of the 3.9
The old 4.1 I was running before I jammed the 302w in for a blast.
For shits and giggles, heres the rust fixing pictures!
Before:
During:
After:
Lastly; heres the old bag herself:
QUESTIONS!
The EA distributer, how can you use it on it's own? It's mostly controlled by the EEC isn't it? How and what does the ign module bolted to the side do?
Where are some pics of throttle cable mounts for the holley series? Hard to find ref pics.
3.9 heads have a softspot for cracking don't they? This engine seems to either have a crack or blown head gasket, gets exhaust gas in the water jacket.
Head swapping? say a 4.0 head onto the 3.9 block? whats the go? Chamber sizes? different gasket? Different passages?
Before:
During:
After:
QUESTIONS!
