Thanks for the info I ordered a new water pump and harmonic balancer yesterday eveningno serpentine water pumps have reverse rotation
I've seen only straight vane pumps, content going either way. (volleyball coach joke here)no serpentine water pumps have reverse rotation
You mean, the larger "exciter" type balancer? I would have thought it the other way around since the smaller, earlier model sits farther away from the cover. What keeps it from going into the cover?I've seen only straight vane pumps, content going either way. (volleyball coach joke here)
Up sides of the late balancer, it can not back in to the timing cover when the rubber fails (nope)
And, the inertia ring can be marked to match the tips on the reluctor, to have an instant visual if slipping goes on.
Sorry, I'd meant to attach the pic, but multi-tasking allows me to screw up several things at once.You mean, the larger "exciter" type balancer? I would have thought it the other way around since the smaller, earlier model sits farther away from the cover. What keeps it from going into the cover?
And plz excuse my ignorance here, but what is the reluctor? I'm honestly not exactly familiar with how this thing is built and mine is a bit too crusty to see it. I may need to dig it out and look at it this weekend.
It looks like that ring is bolted on what is it supposed to do for the harmonic balancerSorry, I'd meant to attach the pic, but multi-tasking allows me to screw up several things at once.
Mechanically attached, not possible to creep. Reluctor=exciter, I meant.
Less familiar with Ford, but the Bowtie bunch usually went up in balancer size/weight, on higher performance engines. Obviously, the MOI goes up fast as diameter increases.
It's bolted to the hub, and the protrusions are triggers for the late EFIIt looks like that ring is bolted on what is it supposed to do for the harmonic balancer
What year models are those on and how does it effect the EFIIt's bolted to the hub, and the protrusions are triggers for the late EFI
They expect you to re-use the OE ring, it seems.I don't think we're talking about the same thing here, and now that I look at the 1996 parts (instead of my 95 ones), the "exciter ring" models aren't necessarily the thicker balancers. I saw the smaller 95s saying they came WITHOUT them and assumed the thicker one was because it had an exciter ring, but apparently that was wrong. What I'm talking about looks like this:
Versus this:
What's the diff and why are they both listed for all years and models? Only the 96 models mention coming with exciter rings, but none show anything like what is shown in the picture you posted @Firepower354 .
Thin ones with extra holes on the back, for the bolt on ring.
WAG: the mass of the wide balancer, is close to the thin with the ring added.
As for the application info on Rock, yeah, nah. They are not always accurate. Finding the fine tooth timing gears the other day, I had to go through several years.
So is it that the one at RockAuto does not have an exacter ring? Does it need one?They expect you to re-use the OE ring, it seems.
Fits 1996 Ford 4.9L F150 F250 F350 Pickup Harmonic Balancer Crankshaft Pulley | eBay
Contents : 1- 4.9 F150 F250 F350 Harmonic Balancer Crankshaft Pulley. 1996 Ford E-150 Econoline 4.9L. 1996 Ford E-150 Econoline Club Wagon 4.9L. 1996 Ford E-250 Econoline 4.9L. 1996 Ford E-350 Econoline 4.9L.www.ebay.com
Do you know anything about these engines RAMPTECH® Ford 300 4.9L Engines their ratio is 8.1 https://www.sagegse.com/ramptech-ford-300-4-9l-engines/ they use those engines in the airport Tugs that pull the planes and baggage carts around my question is about the 8.8 the 8.1The 1991 fuel injection system's ignition timing is calibrated for the EFI fast burn cylinder head and 8.8 compression ratio.
The 1986 engine will not run properly with the 1991 EFI system
Did you rebuild the engine yourself or did you buy oneDo you know anything about these engines RAMPTECH® Ford 300 4.9L Engines their ratio is 8.1 https://www.sagegse.com/ramptech-ford-300-4-9l-engines/ they use those engines in the airport Tugs that pull the planes and baggage carts around my question is about the 8.8 the 8.1
Did you rebuild the engine yourself or did you buy one? If you bought one where at?For the Big Ford trucks, and Industrial type uses the 300’s could have a lower compression ratio this is because of the harder work they needed to do pulling or hauling lots of weight for many hours at a time without overheating. There were ratio’s from 7.5, 8.0, 8.5, 8.7, and the EFI’s with 8.8. For my 1965 F350 300 build I chose 8.0 to 1. Those airport tugs had a very mild 300.
Yeah I checked them out and I'm keeping them in mind I have found that Sage company some years ago after I already got this remanufactured through O'Reilly's and I was thinking that if they use them in airport Tugs might be a little bit stronger and I remember you saying 8.8 and theirs is 8.1 so I was wondering what the difference isI rebuild them myself. A rebuilt short or long block block like this would be a match match for your 1991 EFI engine.
Ford 300 Inline 6 Long 4.9 Block Crate Engine Sale, Remanufactured
Our Ford 300 Inline 6 Long Block Engine is on Sale. Better than a rebuilt 4.9 Crate Engine, this OEM motor is completely remanufactured with upgraded parts.spprecision.com
Well I just wanted a good stout motor that would last for a good while because I need it to pull my 16ft trailer and my 20-foot gooseneck dovetail I went ahead and put the engine that that Precision was that in the shopping basket I think you'll be a lot simpler faster and easier just to get that one in the truck and get the truck going got to wait till they're open to call them about shipping then I guess I'll figure out something to do about the F-350 I sure did like the F-350 for the pulling power I could haul some pretty heavy loads with it besides I already have a 0 mile transmission in the F-150 well it probably has about 25 miles on the transmission now so I just figure why not put a 0 miles or remanufactured engine in front of itYes those air port tug 300‘s I think were a medium duty version it is good motor that would probably be good in an F350 or up. from what i remember they were mostly carb engines when i seen them years ago. Yes if made newer ones those would likely be EFI. If you went with a 8.0 to 1 compression ratio you would be giving up a good amount for of torque and some HP to.
