31 Ford model A patina rod build
Shorty
So I sold my 69 econoline camper van and I guess the money was burning a hole in my pocket. Van wasn't gone for 2 days when I found a model A body with a Nicely started chassis. Front axle is '40 so it has hydraulic brakes, a 9" rear is under the back. One big problem is the 350/th350 that was nestled between the frame rails. Plan is to replace it with the 300 and m5od i have in my 83 f150.
The car has some pretty solid bones but will need a lot of work. I don't anticipate being able to drive it for a couple of years so if you follow this build thread then hang in for the long haul.
Shorty
since the car came with no means of turning the input to the steering box other than a pair of vise grips I thought it would be a good idea to start thinking about a steering column. I had in my stock pile of random leftover parts from past projects a steering wheel and upper column from an early 80's ford 5000 dump truck
With a little cutting and some chain and a tapered bucket, a series of TIG tacks and the problem was solved
Some day when I get a bit of free time and some motivation I will mount it in the car with more than wire and extend the shaft to connect to the steering, but this small step is a step closer to better steering control, and I even managed to find the turn signal switch. Now I need to dig up some turn signals.......
