I finally took our 1968 falcon 200 on the work commute today. left the house at 3;30 am. running very fine, watching the water temp and oil pressure at 190/30 respectively. the last 15 miles I pushed it pretty hard at 80-85. the temp started to climb and was up to 215 when i got off the freeway at work. oil pressure at 20. i had eased up the last couple miles on the freeway to see if it would recover, which it did not. i pulled into the gas station and let it idle and it seemed to cool down just fine. oil pressure still at 20. i am running valvoline 20w50 durablend.....planning to switch to pure synthetic in a while.
Now, at 2 hrs later setting in the work parking lot, it has cooled down. restarted and pressure at 30. it took 2qts of water to top it off.
Just for your info i am running big dia tires 225/75r14@ 84" circumference and 2:83 axle with c-4 so my engine isnt working that hard. I am using a new 180 thermostat.
i have not checked my timing but i am going to check and set it at 10btd.
i havent done any work to the radiator. is there a better radiator or should i just use a stock type? i could probably rod my exsisting or recore it with a thick or high efficiency core.
i would appreciate any comments on my conditions or your similar experiences or suggestions, thanks frankie
