REMOVE **
If you can't sell it all as a lot, I'd be interested in the following:
2 sets of new Comp Cams 8.35" hardened oil thru 200 pushrods--ball & ball
1 set new hydraulic oil thru lifters 16 ea
1 ea used Aussie 250 2V intake manifold with Holley 2 bbl & Weber 38/38 or 32/36 2bbl adapters
4 ea new Aussie 250 2V intake manifold gaskets
2 ea Ford steel shim head gaskets 200/250
1 fresh machined Ford 200 crankshaft with Clevite main & rod bearings
Just getting inline if no one buys it all.
You might be able to get a bit more for the CI head if you post it separately. A lot of people are looking for one.
Ralph is in OK city and from experience great to do business with.
I have decided to sell off many of my SBF 6-cyl project parts.
I have all kinds of SBF 6 cyl parts, stock & performance oriented. I am close to the point of taking pictures. I have finished sorting thru the closet now. I will add to & update this as I go. I have discovered parts that I forgot I had. I have considered & will sell off parts separately or as a whole lot. I am open to offers, if anyone wants to stop by OKC & review the lot. I will ship parts. Prices don't include shipping. I will now work on listing parts separately with pictures. You are welcome to come & look if you live locally in OKC. You are welcome to ask about parts availability. You are welcome to make offers on individual parts or grouped parts lots. Thank you for your patience. It has taken much longer than I thought it would.
Just to start with some simple things:
2 sets of used Ford rocker arm assemblies with bolts-1 adjustable & 1 non-adjustable set-$100 set
2 sets of new Comp Cams 8.35" hardened chromemoly oil thru 200 pushrods--ball & ball--$100 set
3 sets new Sealed Power v-1585 1.38" exhaust valves 18 total--$6 ea
3 ea used camshafts for regrind--1 ea hydraulic & 2 mechanical--$40 ea
2 ea used 1.75" dia big log carb spacer plates--non water cooled-$40 ea
2 ea used 1.5" dia small carb spacer plates--water cooled-$35 ea
2 sets used Ford high nodularity iron 170/200 rod sets--$60 set
1 set Ford E1ZR .040 oversize (255 V8 pistons)--6 total with Sealed Power ring set--$120 set
1 set 170 Silvolite .030 oversize pistons with Hastings ring set--$60 set
1 ea used 250 Ford cable pull low mount manual trans SROD 4 speed bellhousing--$150
2 ea used 200 Ford cable pull high mount manual trans SROD 4 speed bellhousings-$250 ea
1 ea new 250 zero balance SFI 157 tooth C4 auto trans flexplate--$150
1 ea used 200 manual trans steel block spacer plate--$60 ea
Thank you again for your patience.
Ralph
Hello my friend . You should post this stuff on the Vintage Mustang forum & the Vintage 6 Mustang facebook fotumn. You want I can mention this site when I visit either. I see people looking all the time. Take care
Wayne
