^^^ is the title to this thread below.
www.cargurus.com
Im looking at a van that has the same problem. He says... "Yes. It starts right up. It just doesn't like to go far before stalling out. Like 20 to 45 min sometimes less sometimes more." Very similar problem it sounds like.
I have a few ideas on what it could be.. IAC, PCM relay, ECU. Bad ground? Timing? Fuel pump? (has new dist, plugs,wires,fuel filter, starter,alt,egr valve)
What do yall think? (heres the zinger, the van is about 1k miles away from me, i'd fly out, so i need to be able to fix it so i can drive it back lol.)
Ford F-150 Questions - 88 f150 4.9 straight 6 stalling when engine warm - CarGurus
88 f150 4.9 straight 6 stalling when engine warm - I start the truck runs okay then when it gets warmed up the rpms start bouncing around give it gas to tr...
