rommaster2
Ok well today i was attempting to take my falcon down to get the vin inspected so i can officially register it. I get to the gas station, everything is working great, put some gas in, then i realise i forgot something so i head home. As i'm nearing my neighborhood the engine just dies. So me and my friend coast as far as we can (in the residential) and pull over to inspect. Well electrical problems were my first thought, but all was fine there, so we checked out the carb.
Gas wasnt getting to it, we checked by unplugging the fuel line and turning over the engine, no gas poured
. So then we get it home, figuring its clogged or something, starts right up, seems to be running fine, ok just jitters i hoped. So we drive it again, it gets about halfway to the dmv, and decides to die again, this time on a two lane country road without any real shoulder. So we pull off the road (note in a ditch
) and check, its the same darn problem.
Well we were wondering if it was the fuel pump, so we tried to limp it over to a nearby friends house to borrow her electric fuel pump and hopefully get my car home (i'm now thouroughly freaked out about cops hassling me because i'm not registered). So we get there, barely, basically we had to turn over the engine till it would get gas (quite the guessing game, very intermittent) and then give it gas to start it then run till the "primer" gas ran out, then repeat. After installing the electric fuel pump (ghetto rigged) it "seemed" to be happy, so we headed back to my house, hoping to get it on the open road and build up speed then coast if it died. No sooner do we get far enough away from her house to be a hassle does it start to do the same thing. So we repeat this process, and manage to get it two blocks from my hosue in the gas station parking lot.
Now this part of the story really isnt importatn, but for a good story must be told. Me and my friend decide we need to tow it back (the battery is by now pretty much dead) but how? So my friend goes to my house (my sis picked him up) and gets our project lawn mower (an old craftsman with a 15hp single piston Briggs and Stratton motor, does wheelies stock so far) and drives it through the neighborhood to the gas station. Then we hook up a tow strap, put the falcon in nuetral, and we're off, towing my car through a neighborhood with a lawn mower at 6mph. We got home just fine, and got quite a few looks, laughs, and thumbs up from guys in trucks
My theory behind its sudden problem is the fuel sending unit, the car is acting like it is getting clogged, then unclogged as it sits. This would make sense seeing as how i didn't replace the sending unit, and it was missing the filter. Either that or its my fuel pump, which after using the electric one, i have decided to maybe switch over to one of those. Where would i find a plug for the manual? I could keep it on the car for now, and just bypass it right? or would that burn it up? I'm thinking along these lines just because if my electric pump died, i'd like to have a backup available.
So do you guys think its the Fuel Sending unit? Either way i should probably replace that right?
