adapter for a 2100 on a 223?
edgewood bronco
For the 223, does anybody know of a source for a 1 bbl manifold to 2 barrel autolite 2100? Sick of the fuel leak on my glass-bowled holley and am so far impressed with the 2100 on my 200. Obviously changing manifolds would be preferable, but I'm looking for a cheaper, faster solution. Which will I guess then require a distributor upgrade...and most likely a new oil pump, but getting ahead of myself here.
Thanks!
TransDapt makes some 1V to 2V adapters, here is one in below link, Clifford also use to have them so you could also try them. For a distributor Mallory made duel points back in the day so you could hunt for a used one, or you can swap in a 300 Ford Dura Spark II with a little work. Good luck :nod:
http://m.summitracing.com/parts/trd-2044
Nice! that looks like exactly what I want.
I'm going to go the 300 DSII route, which I guess involves getting a newer oil pump than what is probably currently in my '62. This is thinking several months if not a year ahead though...
