Stryker7314
just posted Marco on a make do.
see it under " On the 200..."
I'm not sure what this is saying?
There is an early Maverick 8" axle with 4 lugs.Anyone know if the 7.25 rear will be able to handle this engine along with the t-5 trans? I really don't want to have to swap it, I like the stock look and 4 lugs/ hubcaps
I don't plan to drive it hard or do launches, it's mostly a cruiser but will go wot while rolling already on occasion.The 7-1/4'' will fail if you drive it hard. When my 200 was stock it failed but it was driven like it was stolen. An 8'' will fail if you have a stiff clutch and big sticky slicks and do drag type starts. Just use it till or if you have problems.
With hub caps the bolts should be not seen.
&a... dipstick, I'll let yall know if it works.
