Adjustable Rocker Assembly
SteveStang
Hi All
Just purchased and received my adjustable rocker arm assembly and rods to go with it from classic inlines and was wondering what kind of clearance I will need.
All replies will be appreciated.
SteveStang
HI
shouldn't have any issues it would think.... OH DuH....
do you mean how to adjust them??
If you have hydrolic lifters then its 1/4 to 1/2 a turn from lightly seated.
I like the EOIC.... way....
1) rotate the motor by hand .... just at the Exhaust valve starts to open adjust the intake valve of that cyl. rotate push rod with finger tips just as you fell drag on the rod go another 1/4 or 1/2 turn more..
2) rotate motor by hand .... just as the intake valve starts to close adjust the exhaust valve of that cyl. same was as above....
Hope this helps
Tim
