dawnovsky
Hi,
I m definitly going to need help to adjust valves properly.
I have performed the method proposed by the forum. It ends up with an almost good situation, but still have a bit of valves noise so i have warmed up the engine, remove the valve cover and was really surprise to find out that all valves needed adjustement despite the fact they all all been set the day before.
so i decide to give it anoyther try.
set the engine to Cyl1 TDC, adjust number 1 I and E, N°2 I,n°3 E, etc etc, and realise when done that n°1 push rod can still be turn between fingers.
I then understand that valve spring where pushing on the lifter, allowing oil to leave the lifter and making new play after a few sec or min. (i ve read someting similar earlier in the forum)
I keep trying until i get to a point where it was no more possible to twin rocker even after a few minutes, just to see how it goes. As i was expecting, it end up with a "never closed" valves and zero compression situation.
Assuming then that lifters where fully collapse i ve start again backing off adjuster and performing the initial adjustment procedure.
so the questions are :
are my spring to strong for the lifter ?
if yes what are the option?
how can i properly set those valves ?
ps : current situation is not too bad but can probably be improved.
many thanks
many thanks
