aluminum flywheel???
The flywheel may be the same as the flathead V8s. I can check next weekend for you and see.
Ya, that would be great. Actually if i can get to a buddys house i just pulled his trans so i can maybe check out his flathead. I didnt even think of that. I know the clutch and pressure plate are the same. I just checked and the ring gears are the same in the book so now ill check the flywheel.
Thanks, Travis
