I'm seriously thinking of reworking my pulleys, fan and radiator on the '62 Ranchero. Tired of marginal cooling on 100-degree days with the a/c on, not to mention the a/c compressor loads on the water pump.
My plan is to go to a double-groove crank pulley, and run the a/c compressor straight off the crank instead of through the water pump. I think I can put the alternator back like Ford intended, driven off the water pump belt. Plus, I'm wanting more cooling capacity than the original-type radiator provides, so I'm looking into aluminum radiators, and I don't mind moving it forward if needed. I can go electric or engine driven on the fan.
Anybody got any good sources or references? I've seen posts where people used something like an S-10 rad in a Mustang, but not much for Roundbodies.
