AMC six in a Rambler convertible
thom
I'm thinking about buying a '64 Rambler 440 convertible that has had a Ford six swapped in. It also has the Ford automatic transmission. I don't yet know the model or size of the engine. The current owner believes it to be a 200. I'll post more info and some questions soon.
thom
Yes, it appears to be a 223. Anyone know when the valve cover on 223s changed from center bolts to perimeter bolts?
Frank
Supporter 2021
They are good engines. Even if you get it running without tearing into it, I strongly recommend at least changing the timing chain. It has a chain, not gears, and they wear a hole in the bottom of the cover when worn.
